Dashcam Install
Jason L
Mount Pleasant, SC
2019 Ranger XLT 302A
Was planning on installing a Blackvue dr900s 2ch with power magic pro hard wired.
I see that Ford has an OEM that is 1080P just put on the accessories page. Three questions:
1) Does anyone see specs (wifi, gps, parking mode, etc) for the OEM unit or who makes it, what model it is?
2) I like that it seems to come with a factory harness as I think its a much cleaner install than fuse splitters. Anyone know if we can just buy the harness for use with the Blackvue?
3) If no harness avail standalone, has anyone figured out what fuses to tap?
Trucks on order so need to fill my time buying accessories.
rangerdanger
SF Bay Area
I was planning to install a dash cam myself, I think this thread can serve as info for all.
1) Thinkware is the brand based off photos, not sure of what model #.
2) I doubt it
3) I’ve already done some of that research, but we can use this thread to consolidate all our info.
Edit: These threads have some good info:
https://www.ranger5g.com/forum/thre...-local-dealer-my-impressions-and-photos.1399/
https://www.ranger5g.com/forum/threads/interior-pictures.1053/page-5#post-15022
j0shm1lls
Josh
SoCal, USA
www.youtube.com
2016 Focus RS, 2019 Ranger SCrew Lariat FX4 Sport
I have a Thinkware F700 front and rear in my RS and a Thinkware F770 front and rear in my wife's Edge. Both with the celllink battery backups. I'm probably about to pull the trigger on a F800 Pro for the Ranger.
Here's the RS install.
Crismac
Cris
Kansas City , Missouri
1998 Ford Ranger XLT, 2019 Ford Ranger XLT
Railroad Conductor
I have a Vantrue dash cam X3 with the hardwire kit. And a Samsung EVO 128gb chip. it is all in the box, waiting for the truck.
Bubbabiker
Ford F150 Supercrew FX4
I have a Vantrue X3 in my F150. Love it. Not a big fan of suction cups so I modified for magnetic mounting.
Crismac
Cris
Railroad Conductor
Nice yeah I have never have had a dash cam before. I read a lot of reviews and I kept on going back to this one
On the suction cup, I did read that was the biggest complaint that the suction cup that came with cam sucked so to speak :blush:
I guess the company put out a better suction cup for 5 bucks more, so I ordered that and going to see how that works.
Crismac
Cris
Railroad Conductor
I am going to put this on my amazon wish list. If the new suction cup doesn't work, I will defiantly get that magnet and try it out.
Thanks for the link.
Bubbabiker
FYI I used GE Type 2 Silicone adhesive to secure the metal plate to the suction cup. The contact area between the plate and the suction cup is very small and not sure if the VHB tape will hold over time.
Crismac
Cris
Railroad Conductor
I will keep that in mind, thanks for the tips.
Jason L
Mount Pleasant, SC
So it looks like the OEM kit includes an ignition Pac IGN-3 (what I can make out from the image) that is supposed to make the camera work with the auto start stop (so the camera doesn't think the truck is turned off and go into park mode). I am wondering if that is needed to install a camera with the power magic pro, or if the power magic takes care of the potential delay in ignition power. There must be a reason they are including that device.
https://pac-audio.com/catalog/signal-triggers/ign-3
I remember the old days where a fuse had power when the car was running... simple... but now I am wondering if all the accessories are on some type of communication bus.
rangerdanger
SF Bay Area
I have attached the passenger compartment fuses. We just need to find a fuse that won't get turned off by auto start-stop.
j0shm1lls
Josh
SoCal, USA
www.youtube.com
So in order to properly hook up a 3 wire dash cam you need:
  • Continuous - Preferably one of the spare fuses with at least 10A if using a battery backup or 5A is fine if wiring directly to the camera, should be 12v all the time regardless of ignition (I used the "Luggage compartment lid release" fuse in the RS)
  • Ignition - Should go 12v when ignition is on and immediately off when ignition is switched off, in my RS I had the best results with the "Voltage Quality Monitoring" fuse as it maintains 12v even when the auto start/stop engages. Unfortunately this is in the engine compartment in the Ranger so we'll have to find an alternative on the passenger compartment fuse box
  • Ground
I'll get to probing as soon as I get my truck unless someone beats me to it.
Jason L
Mount Pleasant, SC
I guess my question, is why would a company make the PAC IGN-3, and why would Ford include it in the kit if it wasn't needed.
All the box seems to do is give you those 3 leads, but makes it sound like ignition controlled is not available unless it monitors the bus to determine if its an ignition off, or auto/start stop.
I also see some dashcam threads where people with newer cars are being called idiots for wiring their cams wrong because they go into park mode on auto stop. The DIYers cant find an ignition only trigger.
So lots of technology in this truck, that IGN-3 device must do something of value.
