Damper Disable Feature…
The tailgate is hollow so why not add sand to it. Start with maybe 2 pounds and add a little more each day until you reach your final workout goal.
I bet within 2 weeks you will be able to toss the damper, drain the sand and be back to a predamper mental state.
:stop: You never remove a damper once installed.
That's just bad juju! :devil:
Scottopia
Scott
Mooresville, NC area
'19 Ranger Lariat FX4, '11 GMC Acadia, '03 HD VRod
Grand Sovereign Monarch of Scottopia
Sounds like someone is having issues with his tailgate damper. :shock:
In that case I'd better start adding these as an option at checkout. ?
Well I guess it all depends on what you do with it behind closed doors. :shock::lipssealed:
Not sure if there is a warning on the packaging or not but… Dampers and rubberized battery operated devices should never be paired. You don’t want to be explaining to ER doctors and residents what happened and how it happened!
Progeny2021
Charlotte, NC
Recalling the Music Boxes of yore. I want my damper to play a sound track every time the tailgate opened....
Racket
Here and There
2019 Lariat Supercrew 2WD
Transient
Cmar
Cam
Australia
Ford Ranger PX
Medical Scientist
That's right, and more in fact, once a damper is installed you can never leave, never. If you try to remove it and return to pre-damper life, the damper people will know, and will send out damper enforcers. You and your truck ( with damper) will disappear!
deleriumtremor
Bill
Boise ID
2022 Ford Ranger XLT FX4
Is there a way I can disable the tailgate damper without removing it? You know a switch or something.. only to be rarely used.
It would be nice to show off to the ladies that I can handle a tailgate without the need for a damper..
Hey you all know when that moment arrives, I just want to be ready!!
You didn't get the remote in the box? :(
Better start a delete thread. :)
