"Safe" towing limit without trailer brakes
MichMan
Michigan USA
2019 Ranger XLT 4x4 2010 Ford Explorer
I plan on using my Ranger to tow my utility trailer and ATV during the summer, which combined weigh in at around 1800-1850 pounds. I do not have brakes on my trailer, and after reading the lengthy threads on Ford deciding not to install a controller with the towing package, I'm not sure if I will install one right away. The manual states that the towing limit without trailer brakes is 1650 pounds. I'm sure this limit was set a wee bit low to protect any liability for Ford. I'm wondering what would be considered safe in the towing community using standard accepted formulas based on vehicle and trailer weights? And yes, I'm aware I am responsible for towing anything outside the manufacturers limits.
FULLSCALE
Adam
Ontario, Canada
I wouldn’t think you’d have any issues. I’ve towed much more than that with my old Ranger and didn’t have a problem... just be aware of what’s around you and leave yourself some extra space!
Sarge104
Perry
Montana
www.facebook.com
19 FR, 13 VB, 95 GS MH, 00 HE
County Cemetery District, SAR volunteer
*coughs*
2000+ lbs of water, backed uphill no issue. Pulled wonderfully, just have to be careful with brake distances.
NOVA_Ranger
Northern Virgnia
I tow my RZR on a utility trailer with zero problems. Can't even tell it is back there for the most part.
Floyd
illinois
Sounds like the 1650# is an arbitrary 40% of the truck's weight.
That is a kind of common "rule of thumb" number,
Another is the ability to stop within 40 feet @20MPH.
In my state Brakes are required on a trailer which weighs over 3000#.
Most utility trailers don't have brakes, I have towed a 5X10 ft open utility trailer for years without trailer brakes using several vehicles which were less capable than the 2019 Ranger.
I.E. Ford Escape, TC, 2001 Ranger, and more.
I haven't weighed it with every load, but I am often tired and sore after loading or unloading it.
We have often carried stuff like furniture, mass quantities of bicycles, a golf cart, motorcycle, toolboxes, ETC.
Consider that the payload capacity without a trailer ls 1860# on my 2019 Ranger and that the brakes are massive for its class.
A little common sense change of driving habits is always a good idea when towing ,with or without brakes.
Hi Paul,
What is the limit by Michigan law for non required aux brakes in the trailer? I believe this will be your defining legal limit. And your are correct about your responsibility relative to Ford requirements to which you exceed. I towed a race car which weigned 1200 lbs with a 400 lbs trailer....no problems with the Police in Michigan or elsewhere in the country where I raced.
MTB-BRUH
Tyler
Shingletown CA
2019 Ranger Base
Shop Manager
I barely use the trailer brakes when towing my 6000 pound travel trailer. I wouldn’t worry about anything up to 5000 personally. Just gotta be more cautious the more weight you have. The ranger brakes work very well
DrSafety
West Michigan
2019 Ranger Lariat Electric Blue
Michigan State Law requires trailer brakes when the load exceeds 3000 lbs.
Floyd
illinois
we have all seen the occasional haulmaster in a Hyundai SUV, towing the camping trailer for its seasonal trip to Camp Jellystone on july 4th long weekend and the trailer starts swaying and tossing the kids from side to side....not that the trailer was too big or for the SUV or anything...
it comes down to your experience more than anything. Are you comfortable handling what gets thrown at you when a situation developes?
If you're not sure, then you shouldn't do it.
Actually no...
What I have seen a dozen times or more is a fullsized pickup with a toyhauler upsidedown in the ditch because the weekend warrior at the wheel thought he could tow an improperly loaded trailer at eighty MPH going down the road oblivious to traffic with a sway so bad it looked like a ruptured duck at a dead run... And yeah, he surely had trailer brakes.
Floyd
illinois
their experience showed....which was my point.
And a good point it is too!... :like:
At the other end of the spectrum is overconfidence.
It has been said that the most dangerous part of any vehicle is a loose nut behind the wheel.
A careless overconfident experienced driver can often be worse than a cautious novice.
MTB-BRUH
Tyler
Shingletown CA
2019 Ranger Base
Shop Manager
To be honest I’m that guy
