Charge system now
If there is a charging system fault that you need to have it looked at. Keep in mind I would highly recommend having it looked at over at Ford dealer
Ranger3
Ranger3
Dj
New jersey
2020 Ranger Xlt Sport 4x4
Store Mgr
Ok, didn't you tell me that it could be the way I installed my light bar.... I addressed it and took it off the battery terminal..... And I know for a fact my battery failed the test.... I've been driving it around and haven't had any problem since. I reinstalled my light bar and changed the battery. I'm a little confused.
Muscleford
George
Ohio north coast
Retired CFO
Ranger3, for sh..s and giggles ask the Ford dealer about hooking an accessory ground to the battery negative terminal see what they say then post an update on this thread.
Correcting that ground should help yes. At the same time didn't you just state that you replaced the battery? You're still getting a fault message which means you most likely still have an issue somewhere else. Since I'm physically not with the truck it's kind of hard for me to troubleshoot this isn't it? Time to take it to the dealer
I'm going to guess you didn't read the previous post? It already stated not to connect the ground directly to the negative battery post for any added electrical accessory. Not hard to understand
Ranger3
Ranger3
Dj
New jersey
Store Mgr
No u misunderstood me.... All is fine now. I just sent you guys the Ford pass message I got the last time I got the fault when I left work before I replaced the battery..... I'm going to call the dealership and ask about the accessory to the negative terminal... And I will post an update
You can ask them if you want but there's really no need. The book tells you everything you need to know and one of the other members already posted it for you
Ranger3
Ranger3
Dj
New jersey
Store Mgr
Now my next question to you all is should I reset the BMS battery management system.... I'm going to do it I think. Do you all recommend it?
Yes you should reset the BMS. With a new battery you need to do it. If you have the tools where you simply click buttons in order to do the reset, then that would be best. There are other methods that are available with instructions in the owner's manual if you don't have tools to make the reset.
Ranger3
Ranger3
Dj
New jersey
Store Mgr
Thanks I'm all set love all you guys !
So fuse 24 that the light bar is in is enough power to handle the light bar? I mean that can't make an issue can it? Now that it's wired correctly?
Muscleford
George
Ohio north coast
Retired CFO
Ranger3, did you ask the dealer about connecting an accessory to the negative terminal of the battery?
Thanks.
Jason B
Louisiana
2021 XL STX SE 4x2
machinist
Just saying, OEM batteries are good for about 4 years. So, I can see both the battery getting week AND improper grounding cause your issues.
Ranger3
Ranger3
Dj
New jersey
Store Mgr
I will find out on Monday my guy has been on vacation
Thanks.
Why bother asking a dealership when you can just look in the owner's manual? Another member already posted the answer for you
