Catch can for tremor - install location
KrazyTrane
KjK
2023 Ford Ranger XLT Tremor
Lawyer
I plan to get the mountune catch can system when it’s back in stock. The trouble with it, and most other catch cans, is they locate them where the box for the aux witches are under the hood. Has anyone found a dual can with install meant for tremor setup? Or how about install tricks to get these installed in the space available under the hood in the tremor?
puda
Peter
GA
2024 Wrangler
Industrial Automation
If you're looking for a diy solution there are two threaded studs to the left of the aux switch fuse box. I used a piece of aluminum and made a template using cardboard to get a plate to mount a fuse and breaker to. I would imagine it would work fine for a catch can, depending on how big it is.
Bravesfan1995
Ash
Dallas, TX
2023 Ranger XLT Tremor
Construction
any idea what size those studs might be? This is a great idea... I currently have a bus bar for my ground here, but plan to relocate that and install the UPR can in this location.
puda
Peter
GA
2024 Wrangler
Off the top of my head I'm thinking M6. I'll check in a couple hours.
