Careful stepping in the rear bumper
Ranger Roger
Roger
Dagsboro, DE
2015 Honda Fit, 2004 Honda ST1300abs, 2018 Honda HR-V
Boom......
No steppy on bumper now.
I need something like that but one that works with the tailgate down. Does it clear the side of the tailgate? Too old to jump down and don’t like jumping up backwards onto tailgate. Bad knees don’t help either.
Sandman Ranger
Pete
Lead Process Engineer
It clears enough.
You can adjust out some also. Maybe 1-1.5” more than in my picture. I turn around to get down. Left hand on bed side, watch for step between legs, step down. Should be a good option. I can still jump down at 55 but when older we also should get smarter. Give it a try. Solid step also.
Sandman Ranger
Pete
The tire makes a pretty good step for bed side access. As a bonus you aren’t likely to damage it.
But pants leg and shoes can rub paint.
Ok if a farm truck but some want the paint to last.
Deleted member 1634
I feel like the bigger "issue" with using the tire is that it's not much lower than the tailgate (when lowered) or bumper, so you still have to make that first big step. You're not really gaining anything, as far as having an easier step than the tailgate, by using it. It's a perfectly good idea and I've done it plenty of times, but it doesn't fix the step issue in my opinion.
Ranger Roger
Roger
Dagsboro, DE
It clears enough.
Where did you get it from and what is it called or model and manufacturer?
Sandman Ranger
Pete
sbreech
Central Ohio
2020 Ford Ranger XLT
Systems Administrator
After you touch up that scratch, wrap that small panel in clear vinyl. Maybe two layers.
