Brake shudder?
Shane Bevel
Shane
Tulsa OK
2019 Ford Ranger FX4, 1975 Ford F-250 4x4.
I do engage the parking brake when I park...didn't even think about that being a possible cause so I appreciate that perspective!
I literally never apply the parking brake. ha! And mine did the same thing.
PremiumB_rad
Brad
2020 Ranger XLT FX4 Oxford White
Interesting! Well that will ease my reservation with using the parking brake after any intensive braking. Still interested in learning the root cause of this then! It isn't recurring for me yet, 17k on the truck so far and I'm too early in the life of the drilled and slotted rotors to know if they will prevent that.
Shane Bevel
Shane
Tulsa OK
And mine did the same thing with powerstop pads... it's the rotors that are the issue. Not the pads.
KJRR
KJ
Cleveland, OH
Professional Curmudgeon
Are the lug nuts torqued evenly?
TORQUERULES
US
Ranger
I am getting this too. 26k miles. I don't trust dealer techs, so it looks like I am saving for rotors and pads. I knew it was the brakes, this thread just kind of reassured me.
Hi Folks,
I am getting concerned that there is something more going on than just rotor and pads. It may be sticking piston in the caliper is allowing too much heat generation? Don't know, but it is time for Field Service Engineering to start looking at this as a systemic problem on a small portion of the Rangers running around here in the USA. All of the Forum members with this problem, please open up a formal complaint with Ford Customer Care as a first step.
Way back, Ford Truck had a terrible problem with front brakes due to phenolic caliper pistons. On paper these pistons looked good for corrosion resistance, heat tolerance, etc. What was overlooked in the material's propensity to absorb moisture and expand, causing many, many stuck pistons and customer complaints... It took some lengthy time to id and then to fix the issue, thus fix was to just replace with new problem calipers and again resultant sticking issue...
I wonder if something like this is going on with rear brakes on our Rangers....
Shane Bevel
Shane
Tulsa OK
Unless multiple owners across the country all with Ford rangers are improperly torquing their lug nuts every 16-25k miles…. This is just not the issue. Nor is it “you drive too hard” “you ride the brake” “you drive too soft” “you tow a 3k lbs trailer” or any of the other things that Ford has thrown at us with this problem. It’s either an abs programming issue or a caliper issue I think.
KJRR
KJ
Cleveland, OH
May not be everyone's cause but could be one person's cause. Just throwing out ideas for things to check. You can take it or leave it. Doesn't matter to me.:like:
TVRangerSTX
Trevor
PA
I just searched brake pulsing and found this thread....because today just turned 16,000 miles on my 2019 and started to notice a shudder when braking! On the turnpike at speed when braking, also in the burbs coming to a stoplight. Was taking a lawnmower back to my daughter after having it serviced. I was assuming front rotors, but now am going to check tomorrow morning, including the rears. Don't think I had this problem since my 1971 Pinto (my first new car, junior year in college?!!) Thanks for all for the cumulative info, and Phil @P. A. Schilke . This isn't something I want to waste my own money on, hit and miss chasing the solution. Will be at the dealership shortly anyway for oil change, etc. Assuming they'll diagnose and fix!!
Cabose-1
Eli
Student
Hmmm. Mine don't shudder, but they do squeal a lot. That high pitched sqeual. I figured it was all the trailer towing, and hauling.
t4thfavor
Chance
If you’re lucky there is an updated part # that will fix the problem. For me, they just bandaided it 10 times until I was out of warranty.
