Bed Organizer / Tie Down
Andy
Andy
Does anyone here have a good product or method of keeping gear from moving around in the bed? With a bed cover I’m using the bed to hold pelican cases and camping gear but need a way to keep it all in place without making it a 20 min tie and untie situation.
Thanks in advance!
chasvs
Tampa
Thanks in advance!
I use Cargo Bars. Would be ideal for your situation. Several different models, but work pretty much the same. Hers an example:
https://www.homedepot.com/p/Keeper-Ratcheting-Cargo-Bar-47059/207097432
djrobb
Alexandria,Va
2006 Tacoma 4dr Sport Long Bed
Same here. This is the brand I use. Pretty sure both the full-size truck and compact truck one fits. I think the compact one is lighter(in a good way).
Heininger 4015 HitchMate Cargo Stabilizer Bar for Compact Trucks https://www.amazon.com/dp/B000FOL08M/ref=cm_sw_r_cp_api_i_kjH4Cb5FA7STN
Murphie
Lindale TX
2019 Ranger Lariat 4X2, 2023 Hyundai Santa Fe
Financial Auditor - Retired
chasvs
Tampa
I was thinking of making something like this (for grocery bags). But, I think I will also get some cargo bars.
Cargo Bars and "Milk Crates" work wonders for that purpose!
djrobb
Alexandria,Va
If you are considering a bed extender at all that serves the grocery bag purpose well when it's not flipped out.
Rviator
FLA
retired aerospace engineer
There are vertical slots formed into the bed, behind the wheel wells, that accommodate a 2x8. Cutting a board to the correct length to fit will be my first task, when I get my truck.
SandBaja
Larry
San Diego
2019 Silver FX4, 501A pkg, fully optioned,2012 Rubicon, 2017 Cherokee, 2018 Volt
Almost retired
All excellent ideas folks.
CoastieN70
Travelers Rest, SC
2019 Ranger Lariet
I use a "Cargo Bar but mot the one with the ratcheting handle, mine is the "Screw" type, I find it much easier to adjust and lock in especially if I use it near the cab. I also use a milk crate that the local super market was so kind as to leave out unattended...
cujoquan
Jarrett
Erin, Ontario, Canada
2019 Ford Ranger Lariat
+1 for a truck bed extender (I got the Amp Research one). When it's flipped to face in, it works great as a divider that helps keep smaller items in. Keeps propane tanks from rolling around, holds groceries in place, just wide enough to comfortably fit a golf bag, etc.
djrobb
Alexandria,Va
Cargo bar and a row of five gallon buckets. Easy to remove and put a waterproof top on buckets if I need the space
