Bed gaps for tonneau cover
Alex jones
Alex
Tampa, FL
2019 ranger
Hi everyone I’m new here, love the forums so far, many thanks for all the advise I’ve seen so far! Love my first pickup!
I’ve been scouring the forums to find what everyone has done to seal up the gaps in the back of the bed by the cab in the corners. I’ve tried putting a picture up so people know what I mean.
Also, can anyone share pictures of where they’ve put the sealing tape around the tailgate! I can’t find anywhere good to put it so it actually seals.... it’s such a huge gap!
Sooo many thanks in advance!
treimche
Troy
FORT MYERS, FL
2019 Ranger SOLD. 2005 S2000
Accountant
My Truxedo Sentry cover came with a nice piece of thick foam to help seal that open area, but I added more foam to make sure that it won't leak from up in there.
DBaz
Dan
'19 Ford Ranger Lariat FX4
I added some one-sided foam tape up front as well for extra sealing...guess my gap was a little smaller as I used a lot less (OEM folding cover).
I did my rear tailgate seal like in this picture...helps a lot.
I need to put something in mine as I'm getting dust in from the dusty gravel roads. What tape did you use on the tailgate? I've seen quite a few options but not sure which to buy.
MT19RANGER
JERRY
SIDNEY, MT
Is that the FORD soft cover you have? I'm needing to do the same thing to reduce the gravel road dust in the back.
THWG
Atlanta
The Tailgate seal from Extang worked pretty well for me. https://extang.com/maxseal-tailgate-seal
I believe the kit comes with 10' of seal, but you'll only require ~9'.
Any hints or tips on how best to apply it? I'm assuming it fixed the intrusion of dust and water thru the tailgate gaps? I have dust all over my bedrug from gravel road driving.
THWG
Atlanta
I found the following thread to be quite helpful https://www.ranger5g.com/forum/threads/anybody-tried-a-tailgate-seal.2166/
As others point out in that thread, you'll find best results by aligning the seal with edge of the bed near the taillights. As to the bottom of the bed, I placed the seal on the bottom lip of the bed, not the tailgate. The results seem positive so far, but we haven't had much rain since I installed.
Thanks - I'm more worried about the dust than a bit of water. I remember seeing that thread now. I will refresh my memory.
Thanks again for the link.
THWG
Atlanta
I doubt the tailgate seal is going to hurt your fight against dust intrusion. Good luck!
DBaz
Dan
I used Maxseal like THWG suggested.
Hounddog409
Tod
Ohio
F150
Extang Trifecta 2.0 did not require anything outside the box it came in. metal bar with foam for front gap. everything else is solid. no leaks.
Alex jones
Alex
Tampa, FL
2019 ranger
Thanks! Did you use a tailgate seal too? No leaks is what I’m looking for!!
Alex jones
Alex
Tampa, FL
2019 ranger
I did not seal the tailgate. Havent noticed too much of anything getting in there
Wow ok thanks! Such a huge gap I just assumed you’d get some water on a downpour. Maybe it’s just my brain, I life in Florida, a 5 minute storm can give you a huge amount of water!
