Bakflip mx4 draintube
Jmarler
Jimmy
San Antonio
2026 ranger raptor
Certified Hacker. Retired Veteran
The tube on passenger side keeps falling off, anyone have suggestions on how to make it stay without supergluing it?
JesseS
Jesse
NorCal (Roseville)
In my case I smeared the inside with a thin coat if silicon adhesive, holds it but you can twist it off if needed. I went with the upper holes and cut the tube in half so not much weight to pull it out.
Jmarler
Jmarler
Jimmy
San Antonio
2026 ranger raptor
Not a bad idea. I'll try that
awd.nv
Anthony
Las Vegas, NV
'21 Ranger XLT Tremor
Computers
Falling off from the MX4 side or the chassis side? I used zip ties on the MX4 side and have not had issues since. The Truck side locks in perfectly for me.
JesseS
Jesse
NorCal (Roseville)
I am confused, the MX4 connection is just a push on, I assume where you use the zip tie. The truck end just is pushed thru either the uper bedside hole, or drill a hole in the plastic pop in cover on the bed front on both side, nothing to 'lock' in, at least on my 21 XLT.
awd.nv
Anthony
Las Vegas, NV
Computers
By lock in, I mean that the bedside hole is small enough to lock the corrugated tube into place by biting into the hose in-between the ribs. The only area that popped off on my truck was the MX4 side that is push in. Zip ties fixed that for me.
JesseS
Jesse
NorCal (Roseville)
Got it :thumbsup:
