Bakflip MX4 Install Questions
Cwbyfan62
Simi Valley, CA
2020 Ford Ranger XLT
I work
I've had several recommendations for a hard bedcover.
I'm pretty sure I want the MX4.
But I have a couple questions about the install.
I have a drop in bed liner that I would like to keep for the moment.
Is that possible?
And if I do keep the liner, how challenging does that make installing the water drains for the MX4? Can it be done?
No matter what cover I choose, drainage will be an issue with the bed liner?
2020 XLT Supercab 6' box
I’ve been looking at this cover for the same truck. Does your liner cover the inside lip of your bed? Pretty sure access is needed the full length to attach side mounts for this cover.
I’m doing LineX on mine as my last Ranger had a drop in and it made me not want to do it again.
Cwbyfan62
Cwbyfan62
Simi Valley, CA
I work
Yes, I have access to the inside lip. The drainage is my only issue to resolve, I think.
I would call them and ask. You most likely are not the first one to inquire about this
Sign1941
Maine
2020 XLT/FX4
Is that possible?
[/QUOTE
You can do with a drop in liner...see installation instructions attached! I love my BAKFlip (I have a spray in liner)
DHH
Here...but sometimes there
2019 Ranger Lariat FX4
I have the factory hard tonneau and use to have the bedliner as well. It's not an issue. Just run the drain lines through the bedliner and then through the box.
