Anyone try these yet??
KnightRanger
USA
2020 Ford Ranger, 2016 Harley FLSS,
I bought similar “fan-less” ones from Amazon.
They‘re 1:1 same size as 9005/ hi beam and H11 / low beam and fog leds.
(MarsAuto brand)
KnightRanger
USA
Alex Bedrosian
Alex Bedrosian
Alex
Salt lake city
Ranger xlt fx4
I just recently ordered the sealight s1, fanless, looked good, see how they go.
How are these? Were they easy to adjust??? Any photos?
KnightRanger
USA
Since they are same size as stock, and if installed properly, the sides should line up (similar to how the stock halogen filaments are oriented). I didnt have to adjust anything.
They are definitely a big improvement over stock(yellowish) halogens.
The leds are brighter/ whiter.
micl9
Apex, NC
2019 Ranger XLT Fx4 302A
Id like to hear if these are still working after the (next?) summer - LEDs HATE heat and Lumens make heat. And the super high output of a headlight in such a small space id alot of heat to draw off passively ( I used to work in LED lighting). Not trying to thread crap, just a heads up to keep your stk bulbs. Maybe in the truck somewhere!
KnightRanger
USA
I always keep spares in the truck, fuse, bulbs, etc..
:D
Def gonna keep an eye on these....But I also heard the ones with the fans are problematic, esp when the fans decide to quit.
I also did not opt for super high lumens, ( e.g. > 12000) as it becomes a wash with the stock reflectors.
The ones I chose (above):
H11 low beams=8000 lumens
Hi beam 9005=8000lumens
H11 fogs= 5000 lumens
ETA: I have no affiliation with any of these sellers or items.
Basically just answering the OPs questions.
micl9
Apex, NC
:D
The ones I chose(above)
Valid point on the fans! Air bearings would be ideal, buyt either way a nasty environment for a fan.
Good Luck! I will go the old fashioned approach and decide after my first head light goes out!
Maybe by then used Lariat lights will be cheaper!
KnightRanger
USA
I dunno man, I’ve had a 2019 Lariat and was not impressed with the LED lighting. ( I mean, its still better than stock XLT Halogens)
I suggest try one first at the dealer, before investing in a set.
micl9
Apex, NC
Or maybe wait for the Morimoto's to come out (and drop in price!).
NoCoRanger
2019 Ranger XLT FX4 CrewCab
KnightRanger
USA
Its tight. ( a bit of a pain esp if you have large hands)
Removing the plastic air dams will help as well as turning the wheels full left/ right, to give you more room.
Reach in from under the bumper and locate the fog harness connector. Disconnect, then turn the fog lamp counter clockwise to remove.
Its tight, removing the plastic air dams will help as well as turning the wheels full left/ right, to give you more room.
Reach in from under the bumper and locate the fog harness connector. Disconnect then turn the fog lamp counter clockwise to remove.
I found it easier to drop the skid plate and reach in from the inside. Only loose the rear bolts and remove the front ones. Then slide the plate out. Only requires one size socket too. :wink:
KnightRanger
USA
I agree.
I should’ve done my fogs when I took the bumper off. lol
( did the winch mount)
@NoCoRanger its size 15mm socket iirc. If you want to remove the front skid plate like Blue suggested.
