Anyone NOT have problems with the Ranger?
kieefer
keith
Vibes and stumbles when new, added a tune and that helped, all cleared up after 30k and premium fuel.
Heater Box failed, warranty covered it.
Rattle in headliner, disappeared around 40k.
Tranny slow to engage in reverse, on-going, 60k.
Radio forgets iPhone is plugged in, reset once a month (?)
Radio never updates.
Floor heating vents are useless.
Still running stock battery.
Living The Dream
The day I changed my transfer case and rear diff fluid it all disappeared. I don't know which one actually fixed it because I did them both at the same time. I noticed the difference simply backing out of my garage. It's been about 25 000 miles ago and still running smoothly. I'm assuming it's the transfer case fluid because my increased torque in 4L easily tripled. It pulls itself, like the crawler gear in the Bronco does. I can get out and walk beside it as moves lol. It didn't do that with the factory juice in it.
I've never been a fan of factory fluids, now I'm even skeptical of the junk ones they use during assembly and/or on the assembly line.
What did you replace the factory fluids with?
I've already done my front and rear diffs and my transmission fluid will get changed this spring when I install my Mishimoto trans pan.
SaturnVVV
2020 Ranger XLT
Interesting, thanks for the context, might have to try this out on mine and see if it makes a difference.
Motorpsychology
Prescott, WI
Vagabond
When I reach 75,000mi, I plan to change all fluids including brake fluid; "If you can pour it, change it." Maybe even the blinker fluid.? I did all that when my '09 Mariner reached 100K, and it shifts smoothly and the drivetrain is quiet. No problems with the 6F35 trans, one of Ford's better ideas
What viscosity blinker fluid did you use ??? And, seeing where you live, do you have to change the blinker fluid to a different mix, like summer or winter mix ???
And, does changing to a thicker viscosity change the "blink" sequence....
like going from blinkblinkblink to blink....blink....blink....
Kodiacnb
Robert
East Coast, Canada
2021 Ford Ranger XLT Super cab
Retired Postal Worker
I read all the messages of people having all kinds of problems with their ranger. Really discouraging. I have a 2020 Ranger XLT with 17k on it,
Anyone got a few miles on theirs without problems?
33000 Km ... No problems, normal wear & tear.
Motorpsychology
Prescott, WI
Vagabond
For vehicles manufactured after 2008, I use ChrisFix™ full synthetic. It contains superkalaphradulistique polymer emulsion precipitate that changes the color temperature slightly in flat or low light conditions for better visibility. and will not harm children or pets:
Bob902
St. Louis
2021 Ranger XLT
RETIRED!!!!
Yes, full synthetic is the way to go. Works in all weather conditions.
lukdeg
Luc
Edmundston
Ford Ranger lariat 2023 Cactus grey
paramedic
LAriat 2023 with 24k miles on it and the only issue I have is when it's very cold, when I press on the feeder, there is nothing moving, not even the RPM but happened once.
beside that, it runs perfectly
Kemo Sabe
Kemo
Upstate SC
2019 Lariat with just under 33k miles.
Only trouble I have is keeping my foot out of the throttle.
41,000 trouble free miles, UNTIL
a message suddenly appears after stops/overnight.
“Turn off ignition-
All good for 41,000 miles THEN;
SYSTEM OF TO SAVE BATTERY
TURN IGNITION OFF OR START ENGINE
“Turn off ignition-
Probably means your battery is about to take a dump....
IdahoRanger
Idaho
2019 Lariat SuperCrew FX4
RETIRED
“Turn off ignition-
Give the battery a charge, and desulfate so you might get some more time with it.
