Another failed AC. 39k miles. 2019
JPB237
Pa
2019 ford ranger
Dealer had to replace the box on my 2019 , $ 3000 dash removal luckily I had extended warranty
SilverSlugger
SilverSlugger
Wally
AZ
2019 Ford Ranger Lariat FX4
Baking
Exact same symptoms as my 2019.
Repair was 11 hours due to full dash removal, and with parts and labor it ran up to $3,600.
I called the Ford corporate customer service line, told em the price I got quoted, admitted I was out of warranty but felt this was such a common issue that I should check and see if they might help me out.
They covered nearly $3k and gave me a 60k maintenance plan under the goodwill program
Others have tried this and it has worked. Others haven’t had the luck. It’s worth trying tho.
Good luck!
I guess this will be my play. Try for the best and start planning on a trade-in or something else due to the dash being molested.
ChuckT
Chuck
Indianapolis IN
2020 Ford Ranger
Building Manager
Well there it goes. Heat on the drivers side only no adjustments. The passenger side works as it should. Really hating Ford and this pos right now. Prolly looking at a 2k bill for the holidays, nice.
I have already experienced this with my 2020 Ranger. It was a cracked distribution box. $2400 later, I am back up and running. Not a positive image for Ford. Heck, I was only about 38k in mileage.
Muffin1
NJ
So you are telling me I only have 9K miles to go before my AC system goes out? Sounds like it is time to trade it in for a newer model.
Yea unfortunately for us there's a lot of ticking timebombs in this Gen Ranger:frown:
Muffin1
NJ
Wonder what the % of 2019's have had this issue ? ? sounds like all of them if you read this forum...
Well you can add me to the list now, just tonite being 33* I had the heat on, during my long trip home, got to be a bit much so I turned it off and heard a cracking like plastic grinding hard to put in words, I immediately lowered the radio pressed the button back on (single zone) heard a lesser sound, off again the louder cracking sound.
I’m only getting cool air and thru the defrost only no matter if I chose dash vents or lower foot well.
Also sounds like the sound is coming from two distinct places one from the right footwell under glove box and the other from the lower portion of the center stack.
I guess I’m off to see the wizard and test out my Flood Ford ESP warranty.
( 2019 XL single zone, 19,120 miles.)
SILK
Ty
Eastern Pennsylvania
2019 XLT Crew Cab Sport, 2018 Santa Cruz Tallboy
IT Director
Let us know how it goes with the ESP. That time of year where we turn the heat on and for many of us, it never turns off lol. Does seem like there are several more people getting it recently.
Muffin1
NJ
Vehicles that are only a couple years old having such a major part failure certainly not from age or usage it's a defective designed part thats ashame.
Also went out to do some errands earlier, i'm getting mild warm air from the vents cooler from the defroster, and it I'm not hearing anymore clicking from behind the radio when I cycle on/off that initial loud creak or grind must have broken it and that's where it's stuck, the sound behind the glovebox sounds normal as it cycles, not stressed or irregular moving sound.
SILK
Ty
IT Director
Vehicles that are only a couple years old having such a major part failure certainly not from age or usage it's a defective designed part thats ashamed.
Given all the issues here and the representative sample that generates for the rest of the Rangers sold, this issue definitely seems like a good candidate for a recall. But I think given the cost of replacement, they may be reluctant to pull the trigger on that. Purely speculation, but I think this is maybe why we have stories of folks calling Ford Customer Care and begging for mercy to be refunded the cost of repair. I think they know it's an issue and anyone willing to ask for help will get it instead of issuing a full-on recall.
Muffin1
NJ
Excellent point.
Chuck
Houston, TexasC
2019 Ranger Lariat Sport
Does this sound like the same issue... 2019 Lariat, 49,000 miles. The passenger vents are always warmer than the driver side. Ang now you can't modulate the temp. in the cabin. My first issue with the truck. No clicking in the dash.
Muffin1
NJ
In my case it only clicked once or twice and now seems to be quiet, you have. Lariat dual zone so a bit more complicated internals.
Also there are a bunch of threads with dual zone trucks having issues check those for comparison.
The only way to know if yours is not working properly is to let the dealer scan it with their tool to see if any codes are present.
