JACKSMYDOG
And the same quote without 3 dots replacing a very important factor.Not sure why you're making it personal. The allowable maximum is set out in statutes and Ford doesn't make laws. See: "The headlamps shall be so aimed that when the vehicle is not loaded none of the high-intensity portion of the light shall at a distance of twenty-five feet ahead project higher . . . than forty-two inches above the level on which the vehicle stands at a distance of seventy-five feet ahead."
At any rate, the issue OP was facing is that they were being flashed by other drivers. It is obvious to that adjusting the headlights to be level with the headlamp assembly can easily either make it so that the beams are blinding other drivers and/or illegal depending on the height of the vehicle.
(1) The headlamps shall be so aimed that when the vehicle is not loaded none of the high-intensity portion of the light shall at a distance of twenty-five feet ahead project higher than a level of five inches below the level of the center of the lamp from which it comes, and in no case higher than forty-two inches above the level on which the vehicle stands at a distance of seventy-five feet ahead.
