Active noise cancellation
Rumill51
Russell
Memphis
2020 Ford Ranger
How can I turn off the Active noise cancellation on my 20 ford ranger
fob63
bill
Springdale Arkansas
2019 ranger
There are many posts on this.
I used FORScan and set this option to off. Do a search here and you will find the answers.
I'm just curious why you'd want to do that? I find my Ranger to be a very quiet ride and I'm sure ANC plays a part in that. Not sure why you'd want to lose that.
fob63
bill
Springdale Arkansas
2019 ranger
I thought he was talking about the engine enhancement sound setting which if you add a sub and amp then there can be some problems of this with the sound injection.
Rumill51
Russell
Memphis
2020 Ford Ranger
I did add a subwoofer and that's when I noticed the sound come through the subwoofer.
Rumill51
Russell
Memphis
2020 Ford Ranger
Thanks will forscan work on my 2020 ranger?
That makes sense. I hadn't thought about that issue.
Barend Steyn
Barend
South Africa
2020 Ford Ranger Wildtrak 2.0 BiT 4x4 D/C
Mining Engineer
Hi,
I managed to switch off the fake engine noise in the '20 Ford Ranger Wildtrak 4x4 2.0 BiT D/C RH drive using Forscan and OBDLinkEX (recommended by Forscan). RH drive units seem not to have the switch avaialable, HEX code to be adjusted. See images attached.
Hope it helps!
