SN13
- Thread starter
- #1
So back when I got my 5G, I put new tires and wheels on it at 6k miles.
You can see my original thread here:
https://www.ranger5g.com/forum/threads/265-70-r17-milestar-patagonia.5535/
Today, I put a new set on at 60k Miles.
54k miles of use. At 50k miles they were still pretty good but on the end of their usable life.
I rotated the entire set everytime I hit an oil change (approx 7-10k miles).
Here are some photos of the old ones.
And now the new ones.
Once I got down to the outer tread blocks they started to get much louder. I was shocked how quiet the new ones were when they were installed.
I ran them at 27-29psi for the life of the tire and had the constant "low tire" warning each day, but I knew it was ok.
If you want a good life out of these, a low pressure seems to work.
Hope this helps everyone.
*** Edited to add***
My personal belief is that these are the keys to long tread life in these tires.
1. Neutral toe alignment.
2. Low pressure (27-29psi) to use the entire tread block.
3. Rotation every 6-10k miles.
