2022 ranger differential cover gasket
ozzy
bob
bucks co. pa.
2022 ranger
I have he rear differential with no drain plug. My question is gasket reusable or do i need to order new one.
BluBusa66
Ron
Sylvania, Ohio
2023 Ranger Tremor
Wholesale Parts Brondes Ford Toledo
IT IS RUBBER AND SHOULD BE RE-USEABLE
P/N KB3Z 4036-A IF YOU NEED A NEW ONE
Mustang2Ranger
Garrett
Southern California
Are you sure?
If you look at it from the rear it only appears there is a fill plug
However, if you look underneath on the driver side you will find a drain plug
Just did mine
Loweredon33s
Baltimore
2021 Ranger
Performance person
I reused mine. I took the cover off so I could get the settled particles out that don’t come out by draining.
Wasn't this a deleted item on newer models?
Don't know for sure...my 2021 has a drain plug. All it takes is a few seconds to bend down and look.
gwhalin
Greg
New York
Yeah my 21 has a drain plug. OP has a 22 and guessing the drain plug is gone.
Not rocket science....someone with a 2022 go have a look-see......
Wytchdctr
Doug P.
Westside Htown, Texas
2021 XLT
Retired Military/HR Manager
Late 21 here; it vanished. Mine is almost a 22. I put pictures to prove it is missing in another thread. You can see where it should/could be... but nope no drain. The service manual changed super late 21; guessing that date is when some of the changes started.
I am going to swap the gasket because relatively cheap vs the oil I am going to dump in it. Peace of mind if anything. Not sure if its meant to be reused or not.
BS67
Brian
Nebraska
2022 Ranger XLT
My '22 XLT doesn't have the drain plug. Replaced the gasket when I changed the fluid. Gasket was cheap enouogh!
shovonmshahriar
US
Ford
Shop manual says the gasket is reusable up to 20 times as long as it is not pinched or damaged. What is the torque speck of those 10 head bolts to install the cover?
The shop manual states 14.75 ft.lb to remove but doesn’t specify if that’s the same to install.
