2019 Ranger XLT RWD- OBD codes: P0141 and P2096
markbro
Upstate NY
2019 Ford Ranger XLT Supercab
na
I just picked this truck up from a used dealership with 85k miles on it.
After putting around 200 miles on it, the engine light came on... sigh
Codes read:
P0141: O2 Sensor Heater Circuit Malfunction Bank 1 Sensor 2
P2096: Post Catalyst Fuel Trim System Too Lean Bank 1
Dealer's shop closes on weekends so I wanted to do a little troubleshooting myself, if I can. Unfortunately I am having trouble finding repair manuals to locate things. I did locate fuse #8 for the oxygen sensors so far.
Any advice?
deleriumtremor
Bill
Boise ID
2022 Ford Ranger XLT FX4
Sounds like your downstream O2 sensor (the one behind the catalytic converter) might be bad. You can test the heater circuit of the sensor with a multimeter.
markbro
Upstate NY
na
That sounds about right. I just need to locate the harness first. Thanks
RangerBill
Here is some info from the shop manual. It would be the lower O2 sensor heater circuit on the diagram. I think the other DTC is related to the O2 sensor heater problem, so concentrate on the heater wiring and sensor heater might be open. I would check the heater with an ohmmeter to see if it is open.
RangerBill
The heater resistance should be less than 5 ohms at the O2 sensor. Voltage to the heater should be greater than 10.5 volts with the key on.
Quick and Simple checks, without having to pull the PCM Connector C175E.
Connector Disconnected: Downstream O2 - HO2S12
Key On - Pin #2 to Grd = Batt Voltage
Key Off:
Pin #1 to Grd
Pin #1 to Pin #2
Pin #1 to Pin #3
Pin #1 to Pin #4
All Measurments above should be >10,000 Ohms or 10 Kilo Ohms
O2 Sensor (Component side)
Pin #1 to Pin #2 - should read (2-30) Ohms
EDIT: I suspect the above is out of range, tripping the code
Pin #1 to Grd
Pin #1 to Pin #3
Both should read > than 10,000 ohms or 10 Kilo Ohms
