2019 px3 ranger auto high beam issues
Dozzer
Darren
ringwood
ford ranger 2019 px3
Hi All
Just confirming if anyone has any issues with auto high beams not staying on with driving light.
I have a led light bar with separate switch and trigger wire off high beam. This works fine with no issues with auto high beam turning on as it should.
I have same set up for my led driving light but when set on is set on auto high beam it only stays on for short time before returning to normal low beam.
If I select manual high beam it works fine and will stay on for as long as I need.
Any advice would be much appreciated.
It's strange no issues with light bar but just with driving lights.
D lights are Kings running through IPF wiring and both driving and light bars are running through relays.
Thanks
k1w1t1m
Tim
Bull Shoals, AR
2021 Ford Ranger XLT FX4 SCREW
This is complete speculation but my guess is that your driving lights are providing too much ambient light. Just like driving in town even with no oncoming traffic the high beam won't come on because of the street lights and other ambient lighting.
Hmm,
Brief operation of control.
The Auto-High Beam Trigger (Off) comes from what the IPMA sees as an oncoming vehicle, sometimes reflections of road signs etc will false trigger them off.
Depending on where the LED lightbar is mounted. the IPMA may be seeing this as oncoming traffic.
Sorry, but define Driving Light (Meaning Fogs)? or Regular Headlights? Low Beam
If I understand this correctly and reading the post again.
You want your Fog Lights (Driving Lights) to be on with your High Beam Headlights?
If this is the case - the BCM needs some Forscan Help as the As-Built data needs changed to allow this.
Since this is a ROW Ranger, it MAY to be different than the US Version
This change is known as Bambi Mode
BCM
726-27-01
0100-0001-0057
Change: xxxx-xxx1-xxxx to xxxx-xxx0-xxxx
1 = Disabled - 0 = Enabled
RangerPNW
Thomas
Santa Fe, NM
I would wager you're throwing too much light, and its reflecting back enough that the truck thinks there is oncoming traffic. I've had this issue with just my standard Lariat projectors and Diode Dynamics fog lights.
For further reference: As to how your extra lighting, may be the trigger
Can the IPMA be changed to allow auto high beam to work sooner, like before it gets really dark out? Why would it allow the headlights to come on but not allow the high beam to work unless it's really dark? I have to manually use high beam at dusk and dawn until it's dark enough.
There is (1) As-Built file that relates to sensitivity.
No idea exactly what does or (impacts) function
Factory (OE) is set to 00xx - so Level 1
I am not sure what (LA Sensitivity (LAS) is, I am thinking Lane Assist (Keeping)
so, if you scroll down to say adjust to Level 2 or Level 3 for the AHB it also changes the LAS to match the same level
So, it APPEARS the sensitivity covers both and no clear description on what this actually does.
Which is common in the breakdown of the As-Built files, now a Ford Engineer would have a full understanding as the (nomenclature) is lacking details
Since we know that the IPMA, is primary for Lane Keeping & Collision Avoidance we at least know its related to those systems, but some of them are most likely for other Ford models with other features.
One thing that confuses me sometimes is Ref: AHB Customer Enabled (ACE) = Off, I THINK this pertains to the (DEFAULT) setting as we have a configurable setting in the IPC to enable it.
As I said, some of the As-Built files are hard to break down, this is an example of it.
So, if one were to play with this and try:
Example: 24xx Level 2 or 44xx Level 3 (AHB), I THINK that when you hit the (Lane Keeping) button on the end of the stalk - The 1st default setting will be Level 2 or Level 3 and then you can adjust the sensitivity level in the menu (IDK, I do not use Lane Keeping) so would have to play with it.
or even if the sensitivity level of the AHB adjustment will actually do anything (noticeable) for Trigger (On) or Trigger (Off)
NOTE: I should point out that any changes made to this setting - MAY REQUIRE a IPMA Recalibration to be performed and will likely trigger a Front Camera Fault until it is completed.
I am not sure - just a hunch as this affects calibration (settings)
706-04-01**xxxxxxxxAHB Customer Enabled (ACE), AHB Sensitivity (AS), LA Customer Enabled (LACE), LA Sensitivity (LAS), LDW Haptic Intensity (LHI)
00=ACE Off, AS Level 1, LACE Off, LAS Level 1, LHI Off80=ACE On, AS Level 1, LACE On, LAS Level 1, LHI Off
01=ACE Off, AS Level 1, LACE Off, LAS Level 1, LHI Low81=ACE On, AS Level 1, LACE On, LAS Level 1, LHI Low
02=ACE Off, AS Level 1, LACE Off, LAS Level 1, LHI Medium82=ACE On, AS Level 1, LACE On, LAS Level 1, LHI Medium
03=ACE Off, AS Level 1, LACE Off, LAS Level 1, LHI High83=ACE On, AS Level 1, LACE On, LAS Level 1, LHI High
04=ACE Off, AS Level 1, LACE Off, LAS Level 2, LHI Off84=ACE On, AS Level 1, LACE On, LAS Level 2, LHI Off
05=ACE Off, AS Level 1, LACE Off, LAS Level 2, LHI Low85=ACE On, AS Level 1, LACE On, LAS Level 2, LHI Low
06=ACE Off, AS Level 1, LACE Off, LAS Level 2, LHI Medium86=ACE On, AS Level 1, LACE On, LAS Level 2, LHI Medium
07=ACE Off, AS Level 1, LACE Off, LAS Level 2, LHI High87=ACE On, AS Level 1, LACE On, LAS Level 2, LHI High
08=ACE Off, AS Level 1, LACE LDW, LAS Level 1, LHI Off88=ACE On, AS Level 1, LACE LDW, LAS Level 1, LHI Off
09=ACE Off, AS Level 1, LACE LDW, LAS Level 1, LHI Low89=ACE On, AS Level 1, LACE LDW, LAS Level 1, LHI Low
0A=ACE Off, AS Level 1, LACE LDW, LAS Level 1, LHI Medium8A=ACE On, AS Level 1, LACE LDW, LAS Level 1, LHI Medium
0B=ACE Off, AS Level 1, LACE LDW, LAS Level 1, LHI High8B=ACE On, AS Level 1, LACE LDW, LAS Level 1, LHI High
0C=ACE Off, AS Level 1, LACE LDW, LAS Level 2, LHI Off8C=ACE On, AS Level 1, LACE LDW, LAS Level 2, LHI Off
0D=ACE Off, AS Level 1, LACE LDW, LAS Level 2, LHI Low8D=ACE On, AS Level 1, LACE LDW, LAS Level 2, LHI Low
0E=ACE Off, AS Level 1, LACE LDW, LAS Level 2, LHI Medium8E=ACE On, AS Level 1, LACE LDW, LAS Level 2, LHI Medium
0F=ACE Off, AS Level 1, LACE LDW, LAS Level 2, LHI High8F=ACE On, AS Level 1, LACE LDW, LAS Level 2, LHI High
10=ACE Off, AS Level 1, LACE LKA, LAS Level 1, LHI Off90=ACE On, AS Level 1, LACE LKA, LAS Level 1, LHI Off
11=ACE Off, AS Level 1, LACE LKA, LAS Level 1, LHI Low91=ACE On, AS Level 1, LACE LKA, LAS Level 1, LHI Low
12=ACE Off, AS Level 1, LACE LKA, LAS Level 1, LHI Medium92=ACE On, AS Level 1, LACE LKA, LAS Level 1, LHI Medium
13=ACE Off, AS Level 1, LACE LKA, LAS Level 1, LHI High93=ACE On, AS Level 1, LACE LKA, LAS Level 1, LHI High
14=ACE Off, AS Level 1, LACE LKA, LAS Level 2, LHI Off94=ACE On, AS Level 1, LACE LKA, LAS Level 2, LHI Off
15=ACE Off, AS Level 1, LACE LKA, LAS Level 2, LHI Low95=ACE On, AS Level 1, LACE LKA, LAS Level 2, LHI Low
16=ACE Off, AS Level 1, LACE LKA, LAS Level 2, LHI Medium96=ACE On, AS Level 1, LACE LKA, LAS Level 2, LHI Medium
17=ACE Off, AS Level 1, LACE LKA, LAS Level 2, LHI High97=ACE On, AS Level 1, LACE LKA, LAS Level 2, LHI High
18=ACE Off, AS Level 1, LACE LDW+LKA, LAS Level 1, LHI Off98=ACE On, AS Level 1, LACE LDW+LKA, LAS Level 1, LHI Off
19=ACE Off, AS Level 1, LACE LDW+LKA, LAS Level 1, LHI Low99=ACE On, AS Level 1, LACE LDW+LKA, LAS Level 1, LHI Low
1A=ACE Off, AS Level 1, LACE LDW+LKA, LAS Level 1, LHI Medium9A=ACE On, AS Level 1, LACE LDW+LKA, LAS Level 1, LHI Medium
1B=ACE Off, AS Level 1, LACE LDW+LKA, LAS Level 1, LHI High9B=ACE On, AS Level 1, LACE LDW+LKA, LAS Level 1, LHI High
1C=ACE Off, AS Level 1, LACE LDW+LKA, LAS Level 2, LHI Off9C=ACE On, AS Level 1, LACE LDW+LKA, LAS Level 2, LHI Off
1D=ACE Off, AS Level 1, LACE LDW+LKA, LAS Level 2, LHI Low9D=ACE On, AS Level 1, LACE LDW+LKA, LAS Level 2, LHI Low
1E=ACE Off, AS Level 1, LACE LDW+LKA, LAS Level 2, LHI Medium9E=ACE On, AS Level 1, LACE LDW+LKA, LAS Level 2, LHI Medium
1F=ACE Off, AS Level 1, LACE LDW+LKA, LAS Level 2, LHI High9F=ACE On, AS Level 1, LACE LDW+LKA, LAS Level 2, LHI High
20=ACE Off, AS Level 2, LACE Off, LAS Level 2, LHI OffA0=ACE On, AS Level 2, LACE On, LAS Level 2, LHI Off
21=ACE Off, AS Level 2, LACE Off, LAS Level 2, LHI LowA1=ACE On, AS Level 2, LACE On, LAS Level 2, LHI Low
22=ACE Off, AS Level 2, LACE Off, LAS Level 2, LHI MediumA2=ACE On, AS Level 2, LACE On, LAS Level 2, LHI Medium
23=ACE Off, AS Level 2, LACE Off, LAS Level 2, LHI HighA3=ACE On, AS Level 2, LACE On, LAS Level 2, LHI High
24=ACE Off, AS Level 2, LACE Off, LAS Level 2, LHI OffA4=ACE On, AS Level 2, LACE On, LAS Level 2, LHI Off
25=ACE Off, AS Level 2, LACE Off, LAS Level 2, LHI LowA5=ACE On, AS Level 2, LACE On, LAS Level 2, LHI Low
26=ACE Off, AS Level 2, LACE Off, LAS Level 2, LHI MediumA6=ACE On, AS Level 2, LACE On, LAS Level 2, LHI Medium
27=ACE Off, AS Level 2, LACE Off, LAS Level 2, LHI HighA7=ACE On, AS Level 2, LACE On, LAS Level 2, LHI High
28=ACE Off, AS Level 2, LACE LDW, LAS Level 2, LHI OffA8=ACE On, AS Level 2, LACE LDW, LAS Level 2, LHI Off
29=ACE Off, AS Level 2, LACE LDW, LAS Level 2, LHI LowA9=ACE On, AS Level 2, LACE LDW, LAS Level 2, LHI Low
2A=ACE Off, AS Level 2, LACE LDW, LAS Level 2, LHI MediumAA=ACE On, AS Level 2, LACE LDW, LAS Level 2, LHI Medium
2B=ACE Off, AS Level 2, LACE LDW, LAS Level 2, LHI HighAB=ACE On, AS Level 2, LACE LDW, LAS Level 2, LHI High
2C=ACE Off, AS Level 2, LACE LDW, LAS Level 2, LHI OffAC=ACE On, AS Level 2, LACE LDW, LAS Level 2, LHI Off
2D=ACE Off, AS Level 2, LACE LDW, LAS Level 2, LHI LowAD=ACE On, AS Level 2, LACE LDW, LAS Level 2, LHI Low
2E=ACE Off, AS Level 2, LACE LDW, LAS Level 2, LHI MediumAE=ACE On, AS Level 2, LACE LDW, LAS Level 2, LHI Medium
2F=ACE Off, AS Level 2, LACE LDW, LAS Level 2, LHI HighAF=ACE On, AS Level 2, LACE LDW, LAS Level 2, LHI High
30=ACE Off, AS Level 2, LACE LKA, LAS Level 2, LHI OffB0=ACE On, AS Level 2, LACE LKA, LAS Level 2, LHI Off
31=ACE Off, AS Level 2, LACE LKA, LAS Level 2, LHI LowB1=ACE On, AS Level 2, LACE LKA, LAS Level 2, LHI Low
32=ACE Off, AS Level 2, LACE LKA, LAS Level 2, LHI MediumB2=ACE On, AS Level 2, LACE LKA, LAS Level 2, LHI Medium
33=ACE Off, AS Level 2, LACE LKA, LAS Level 2, LHI HighB3=ACE On, AS Level 2, LACE LKA, LAS Level 2, LHI High
34=ACE Off, AS Level 2, LACE LKA, LAS Level 2, LHI OffB4=ACE On, AS Level 2, LACE LKA, LAS Level 2, LHI Off
35=ACE Off, AS Level 2, LACE LKA, LAS Level 2, LHI LowB5=ACE On, AS Level 2, LACE LKA, LAS Level 2, LHI Low
36=ACE Off, AS Level 2, LACE LKA, LAS Level 2, LHI MediumB6=ACE On, AS Level 2, LACE LKA, LAS Level 2, LHI Medium
37=ACE Off, AS Level 2, LACE LKA, LAS Level 2, LHI HighB7=ACE On, AS Level 2, LACE LKA, LAS Level 2, LHI High
38=ACE Off, AS Level 2, LACE LDW+LKA, LAS Level 2, LHI OffB8=ACE On, AS Level 2, LACE LDW+LKA, LAS Level 2, LHI Off
39=ACE Off, AS Level 2, LACE LDW+LKA, LAS Level 2, LHI LowB9=ACE On, AS Level 2, LACE LDW+LKA, LAS Level 2, LHI Low
3A=ACE Off, AS Level 2, LACE LDW+LKA, LAS Level 2, LHI MediumBA=ACE On, AS Level 2, LACE LDW+LKA, LAS Level 2, LHI Medium
3B=ACE Off, AS Level 2, LACE LDW+LKA, LAS Level 2, LHI HighBB=ACE On, AS Level 2, LACE LDW+LKA, LAS Level 2, LHI High
3C=ACE Off, AS Level 2, LACE LDW+LKA, LAS Level 2, LHI OffBC=ACE On, AS Level 2, LACE LDW+LKA, LAS Level 2, LHI Off
3D=ACE Off, AS Level 2, LACE LDW+LKA, LAS Level 2, LHI LowBD=ACE On, AS Level 2, LACE LDW+LKA, LAS Level 2, LHI Low
3E=ACE Off, AS Level 2, LACE LDW+LKA, LAS Level 2, LHI MediumBE=ACE On, AS Level 2, LACE LDW+LKA, LAS Level 2, LHI Medium
3F=ACE Off, AS Level 2, LACE LDW+LKA, LAS Level 2, LHI HighBF=ACE On, AS Level 2, LACE LDW+LKA, LAS Level 2, LHI High
40=ACE Off, AS Level 3, LACE Off, LAS Level 3, LHI OffC0=ACE On, AS Level 3, LACE On, LAS Level 3, LHI Off
41=ACE Off, AS Level 3, LACE Off, LAS Level 3, LHI LowC1=ACE On, AS Level 3, LACE On, LAS Level 3, LHI Low
42=ACE Off, AS Level 3, LACE Off, LAS Level 3, LHI MediumC2=ACE On, AS Level 3, LACE On, LAS Level 3, LHI Medium
43=ACE Off, AS Level 3, LACE Off, LAS Level 3, LHI HighC3=ACE On, AS Level 3, LACE On, LAS Level 3, LHI High
44=ACE Off, AS Level 3, LACE Off, LAS Level 3, LHI OffC4=ACE On, AS Level 3, LACE On, LAS Level 3, LHI Off
45=ACE Off, AS Level 3, LACE Off, LAS Level 3, LHI LowC5=ACE On, AS Level 3, LACE On, LAS Level 3, LHI Low
46=ACE Off, AS Level 3, LACE Off, LAS Level 3, LHI MediumC6=ACE On, AS Level 3, LACE On, LAS Level 3, LHI Medium
47=ACE Off, AS Level 3, LACE Off, LAS Level 3, LHI HighC7=ACE On, AS Level 3, LACE On, LAS Level 3, LHI High
48=ACE Off, AS Level 3, LACE LDW, LAS Level 3, LHI OffC8=ACE On, AS Level 3, LACE LDW, LAS Level 3, LHI Off
49=ACE Off, AS Level 3, LACE LDW, LAS Level 3, LHI LowC9=ACE On, AS Level 3, LACE LDW, LAS Level 3, LHI Low
4A=ACE Off, AS Level 3, LACE LDW, LAS Level 3, LHI MediumCA=ACE On, AS Level 3, LACE LDW, LAS Level 3, LHI Medium
4B=ACE Off, AS Level 3, LACE LDW, LAS Level 3, LHI HighCB=ACE On, AS Level 3, LACE LDW, LAS Level 3, LHI High
4C=ACE Off, AS Level 3, LACE LDW, LAS Level 3, LHI OffCC=ACE On, AS Level 3, LACE LDW, LAS Level 3, LHI Off
4D=ACE Off, AS Level 3, LACE LDW, LAS Level 3, LHI LowCD=ACE On, AS Level 3, LACE LDW, LAS Level 3, LHI Low
4E=ACE Off, AS Level 3, LACE LDW, LAS Level 3, LHI MediumCE=ACE On, AS Level 3, LACE LDW, LAS Level 3, LHI Medium
4F=ACE Off, AS Level 3, LACE LDW, LAS Level 3, LHI HighCF=ACE On, AS Level 3, LACE LDW, LAS Level 3, LHI High
50=ACE Off, AS Level 3, LACE LKA, LAS Level 3, LHI OffD0=ACE On, AS Level 3, LACE LKA, LAS Level 3, LHI Off
51=ACE Off, AS Level 3, LACE LKA, LAS Level 3, LHI LowD1=ACE On, AS Level 3, LACE LKA, LAS Level 3, LHI Low
52=ACE Off, AS Level 3, LACE LKA, LAS Level 3, LHI MediumD2=ACE On, AS Level 3, LACE LKA, LAS Level 3, LHI Medium
53=ACE Off, AS Level 3, LACE LKA, LAS Level 3, LHI HighD3=ACE On, AS Level 3, LACE LKA, LAS Level 3, LHI High
54=ACE Off, AS Level 3, LACE LKA, LAS Level 3, LHI OffD4=ACE On, AS Level 3, LACE LKA, LAS Level 3, LHI Off
55=ACE Off, AS Level 3, LACE LKA, LAS Level 3, LHI LowD5=ACE On, AS Level 3, LACE LKA, LAS Level 3, LHI Low
56=ACE Off, AS Level 3, LACE LKA, LAS Level 3, LHI MediumD6=ACE On, AS Level 3, LACE LKA, LAS Level 3, LHI Medium
57=ACE Off, AS Level 3, LACE LKA, LAS Level 3, LHI HighD7=ACE On, AS Level 3, LACE LKA, LAS Level 3, LHI High
58=ACE Off, AS Level 3, LACE LDW+LKA, LAS Level 3, LHI OffD8=ACE On, AS Level 3, LACE LDW+LKA, LAS Level 3, LHI Off
59=ACE Off, AS Level 3, LACE LDW+LKA, LAS Level 3, LHI LowD9=ACE On, AS Level 3, LACE LDW+LKA, LAS Level 3, LHI Low
5A=ACE Off, AS Level 3, LACE LDW+LKA, LAS Level 3, LHI MediumDA=ACE On, AS Level 3, LACE LDW+LKA, LAS Level 3, LHI Medium
5B=ACE Off, AS Level 3, LACE LDW+LKA, LAS Level 3, LHI HighDB=ACE On, AS Level 3, LACE LDW+LKA, LAS Level 3, LHI High
5C=ACE Off, AS Level 3, LACE LDW+LKA, LAS Level 3, LHI OffDC=ACE On, AS Level 3, LACE LDW+LKA, LAS Level 3, LHI Off
5D=ACE Off, AS Level 3, LACE LDW+LKA, LAS Level 3, LHI LowDD=ACE On, AS Level 3, LACE LDW+LKA, LAS Level 3, LHI Low
5E=ACE Off, AS Level 3, LACE LDW+LKA, LAS Level 3, LHI MediumDE=ACE On, AS Level 3, LACE LDW+LKA, LAS Level 3, LHI Medium
5F=ACE Off, AS Level 3, LACE LDW+LKA, LAS Level 3, LHI HighDF=ACE On, AS Level 3, LACE LDW+LKA, LAS Level 3, LHI High
60=ACE Off, AS Invalid, LACE Off, LAS Invalid, LHI OffE0=ACE On, AS Invalid, LACE On, LAS Invalid, LHI Off
61=ACE Off, AS Invalid, LACE Off, LAS Invalid, LHI LowE1=ACE On, AS Invalid, LACE On, LAS Invalid, LHI Low
62=ACE Off, AS Invalid, LACE Off, LAS Invalid, LHI MediumE2=ACE On, AS Invalid, LACE On, LAS Invalid, LHI Medium
63=ACE Off, AS Invalid, LACE Off, LAS Invalid, LHI HighE3=ACE On, AS Invalid, LACE On, LAS Invalid, LHI High
64=ACE Off, AS Invalid, LACE Off, LAS Invalid, LHI OffE4=ACE On, AS Invalid, LACE On, LAS Invalid, LHI Off
65=ACE Off, AS Invalid, LACE Off, LAS Invalid, LHI LowE5=ACE On, AS Invalid, LACE On, LAS Invalid, LHI Low
66=ACE Off, AS Invalid, LACE Off, LAS Invalid, LHI MediumE6=ACE On, AS Invalid, LACE On, LAS Invalid, LHI Medium
67=ACE Off, AS Invalid, LACE Off, LAS Invalid, LHI HighE7=ACE On, AS Invalid, LACE On, LAS Invalid, LHI High
68=ACE Off, AS Invalid, LACE LDW, LAS Invalid, LHI OffE8=ACE On, AS Invalid, LACE LDW, LAS Invalid, LHI Off
69=ACE Off, AS Invalid, LACE LDW, LAS Invalid, LHI LowE9=ACE On, AS Invalid, LACE LDW, LAS Invalid, LHI Low
6A=ACE Off, AS Invalid, LACE LDW, LAS Invalid, LHI MediumEA=ACE On, AS Invalid, LACE LDW, LAS Invalid, LHI Medium
6B=ACE Off, AS Invalid, LACE LDW, LAS Invalid, LHI HighEB=ACE On, AS Invalid, LACE LDW, LAS Invalid, LHI High
6C=ACE Off, AS Invalid, LACE LDW, LAS Invalid, LHI OffEC=ACE On, AS Invalid, LACE LDW, LAS Invalid, LHI Off
6D=ACE Off, AS Invalid, LACE LDW, LAS Invalid, LHI LowED=ACE On, AS Invalid, LACE LDW, LAS Invalid, LHI Low
6E=ACE Off, AS Invalid, LACE LDW, LAS Invalid, LHI MediumEE=ACE On, AS Invalid, LACE LDW, LAS Invalid, LHI Medium
6F=ACE Off, AS Invalid, LACE LDW, LAS Invalid, LHI HighEF=ACE On, AS Invalid, LACE LDW, LAS Invalid, LHI High
70=ACE Off, AS Invalid, LACE LKA, LAS Invalid, LHI OffF0=ACE On, AS Invalid, LACE LKA, LAS Invalid, LHI Off
71=ACE Off, AS Invalid, LACE LKA, LAS Invalid, LHI LowF1=ACE On, AS Invalid, LACE LKA, LAS Invalid, LHI Low
72=ACE Off, AS Invalid, LACE LKA, LAS Invalid, LHI MediumF2=ACE On, AS Invalid, LACE LKA, LAS Invalid, LHI Medium
73=ACE Off, AS Invalid, LACE LKA, LAS Invalid, LHI HighF3=ACE On, AS Invalid, LACE LKA, LAS Invalid, LHI High
74=ACE Off, AS Invalid, LACE LKA, LAS Invalid, LHI OffF4=ACE On, AS Invalid, LACE LKA, LAS Invalid, LHI Off
75=ACE Off, AS Invalid, LACE LKA, LAS Invalid, LHI LowF5=ACE On, AS Invalid, LACE LKA, LAS Invalid, LHI Low
76=ACE Off, AS Invalid, LACE LKA, LAS Invalid, LHI MediumF6=ACE On, AS Invalid, LACE LKA, LAS Invalid, LHI Medium
77=ACE Off, AS Invalid, LACE LKA, LAS Invalid, LHI HighF7=ACE On, AS Invalid, LACE LKA, LAS Invalid, LHI High
78=ACE Off, AS Invalid, LACE LDW+LKA, LAS Invalid, LHI OffF8=ACE On, AS Invalid, LACE LDW+LKA, LAS Invalid, LHI Off
79=ACE Off, AS Invalid, LACE LDW+LKA, LAS Invalid, LHI LowF9=ACE On, AS Invalid, LACE LDW+LKA, LAS Invalid, LHI Low
7A=ACE Off, AS Invalid, LACE LDW+LKA, LAS Invalid, LHI MediumFA=ACE On, AS Invalid, LACE LDW+LKA, LAS Invalid, LHI Medium
7B=ACE Off, AS Invalid, LACE LDW+LKA, LAS Invalid, LHI HighFB=ACE On, AS Invalid, LACE LDW+LKA, LAS Invalid, LHI High
7C=ACE Off, AS Invalid, LACE LDW+LKA, LAS Invalid, LHI OffFC=ACE On, AS Invalid, LACE LDW+LKA, LAS Invalid, LHI Off
7D=ACE Off, AS Invalid, LACE LDW+LKA, LAS Invalid, LHI LowFD=ACE On, AS Invalid, LACE LDW+LKA, LAS Invalid, LHI Low
7E=ACE Off, AS Invalid, LACE LDW+LKA, LAS Invalid, LHI MediumFE=ACE On, AS Invalid, LACE LDW+LKA, LAS Invalid, LHI Medium
7F=ACE Off, AS Invalid, LACE LDW+LKA, LAS Invalid, LHI HighFF=ACE On, AS Invalid, LACE LDW+LKA, LAS Invalid, LHI High
Wow, I guess I will just deal with multiple left stalk taps! Thanks!
Dozzer
Darren
ringwood
Hmm,
BCM
726-27-01
0100-0001-0057
Thanks mate.
When I make reference to driving lights I mean spot lights at mounted on nudge bar.
As mentioned my led light bar has not issues is only Mr led driving/ spotlights that turn on only for so long then turn off.
It is out in the middle of a paddock so no reflection off any sighs.
Ok, so you have:
Factory Headlamps
Plus: Additional
1. LED Lightbar
2. Driving / Spot - Lights mounted to a (Nudge) bar
Both the LED Lightbar & Spotlights are tapped on the (High-Beam) circuit
All lights work normal - in all positions - (Auto-Headlamp) and Headlamp
Where I am lost - is the Auto (High-Beam) part.
This is a (IPC) configurable selection that can be (Turned On/Off)
This (Function) is provided by the IPMA (Camera) behind the rear-view mirror.
The IPMA - uses what it is seeing in front view of the camera to provide lighting parameters it sees and triggers a signal via HS-CAN2 data bus to the BCM.
It uses the (Conditions) parameters to either send the signal to (Turn On/Off) the High-Beams
So, everything on that circuit - including the LED Lightbar & Spotlights SHOULD trigger off, when the High-Beams are commanded off by the IPMA.
I am not fully understanding here, but I think what you are trying to convey is that:
When the (Auto-High Beam) is selected
Using - separate switched (on/off) for each light source.
and
1. Only the LED Lightbar is switched on - It functions normally
and
2. When the Spotlights are switched on (along with - the LED Lightbar) - the High Beams trigger off, thus killing the High-Beams and LED Lightbar and Spotlights.
3. If you only (switch) on the Spotlights and have the LED Lightbar (off) the Auto-High Beams trigger off and kill the Spotlights with it.
or is it
3. ONLY the Spotlights dropping power, and the LED Lightbar remains lit, when Auto High Beam triggers off.
If I am correct in understanding
Issue #2 & #3 is what you are experiencing
If this is TRUE, then the IPMA is seeing that lighting as (either - not dark enough) for Auto High Beams or it is interpreting the light source as a vehicle lighting source (Headlights) or (Taillights) from a vehicle in the forward view of the camera.
You may try adjusting the Spotlights (downwards) to get the IPMA to respond differently from that lighting source.
