2019 10 speed Transmission Reverse Noise
Chris Frazier
Construction
Hello
my transmission makes a “cla-clunk” noise when I shift into reverse, only when its warmed up. No other issues. Any ideas? Thanks
5thranger
Gary
kansas
2020 Lariat Ranger Rapid Red
Hello
Usually, one thinks the transmission which it could be. Sometimes though it can be the rear differential because of the gear reduction you have in reverse versus in a forward gear. If there is play in the rear differential that is when you will hear it. U joints can also do that. Some of the guys on here have had issues with the rear driveshaft splines as well.
RangerBill
If it isn't loud, I would ignore it, probably normal.
tygr2007
Tyler
Naples, FL
www.tradewindnaples.com
Designer @ Tradewind Designs
Hello
I removed my catalytic converter and muffler, I can't hear the clunk anymore.
Chris Frazier
Construction
I ignored a noise recently too. Then my transmission went on holiday…. Try to address it for peace of mind.
Ive already replaced transmission once before
RangerBill
If you can't hear it in the cab with the doors closed, it is most likely normal. Any vehicle makes noises in normal operation, and it is not logical to take it to the dealer for every noise that is heard, unless it is an abnormal or very loud noise. The clunk going from forward to reverse is normal in any car on the road, an exception may be an EV having direct drive.
carnut122
Tim
GA
1953 F100, 2008 Saturn Sky, 2019 Ford Ranger
Carrier bearing?
