transmission noise
LISANDRO
Lisandro
california
2019 ford ranger xlt
Hello
I noticed since when i first purchased my xlt ranger there is a noise when switching from PARK TO DRIVE AND DRIVE TO REVERSE. Doesnt do it going into Neutral.Is this normal its not the whine by the way more of a clunk. no issues so far.
Hello
Hi Lisandro,
Sounds like possible driveshaft windup.. With the vehicle in neutral and the parking brake applied, loosen the two bolts that hold the center bearing of the front driveshaft...sort of shake the rear drive shaft...it won't move much if at all. Then retighten the bolts as it sort of neutralized the two piece driveshaft assemble. This does not always work, but it is easy and worth a try.
best,
LISANDRO
LISANDRO
Lisandro
california
Hi Lisandro,
best,
Thanks Phil
Is this something that will effect the truck in any way? Thanks for the tip.
Thanks Phil
Hi Lisandro,
Likely not hurting the truck, but without evaluating it I can't be sure. A visit to a dealership for evaluation would be helpful to see if they think it is something more than just a normal driveline clunk.
best,
LISANDRO
LISANDRO
Lisandro
california
Hi Lisandro,
best,
Thank you very much.
Junior Blue
Pete
southern N.J.
2019 Lightening Blue Ranger Lariat Crew
Hi Lisandro
Do you still have the clunk when shifting from Park to Drive? Did you try to loosen the bolts on the center bearing? Did that fix your ckunk?
I have the clunk also as you did, when shifting. Dealer told me that it's normal. I was wondering how you made out with your truck. Mine is a '19 Lariat RWD.
Thanks for any info you can provide.
Pete
