110K+ miles and ZERO issues
5thranger
Gary
kansas
2020 Lariat Ranger Rapid Red
Update... I hit 100k yesterday while towing my 15yo son's new to him,that he saved up and paid for, zero turn lawnmower. Not a heavy load but it was the first time I've towed with it.
100k on a Ranger and a 15 year old saving for a mower both are very good things to hear about. Congrats to you for raising a child with work ethic.
Taconic
Don
2019 STX 4WD
Construction
Just turned 120k on odometer and runs like new. Still on second set of tires, replaced brake pads and turned rotors all around, replaced serpentine belt/tensioner/spark plugs @ 100k, new Duralast AGM USA battery, and two sets of wipers. Mobil 1 full syn oil changes every 8k to 10k, and made sure to never ever change any other drive train fluids. This year she'll get trans, diffs, coolant flushed and replaced.
I'm at 115k on my '19 STX XL. I'm will to keep, lift and tire up with only two frustrating issues: soft ride(mod can cure) and the clunky trans with too many gears. I drive in S mode on secondary roads in 6/7 and 8th gear. Have they cured this issue with the '24? BTW, original front pads still!
ScarzRanger21
Auberry
electrician
Wife and I both have rangers, hers is a 2019 fx4 XL and mine is a 2021 4x4 XLT. Only issues I’ve had with mine is suspension problems and worn ball joints due to incorrect parts being used on the original lift kit. I don’t blame the truck for that, this was incompetence on the mechanic’s behalf…
Other than that, no serious issues to report. Both our trucks are running great and have been reliable so far. Even after wrecking mine a couple months ago and having the front end rebuilt, she’s still running solid.
harringtondav
East Central Iowa
I have 32K miles, so too early to report. But I find comfort in these 100K+ reports. I don't loose sleep over the 10R80, but it is in the back of my mind. Pretty sure its failure rate is well below 100% Hope the odds are with me.
95k and zero issues except….
transmission, DPFe sensor, front diff leak (warranty) and sync issues (cyanlabs)
yup completely trouble free!
95K eh? Why does that number ring a bell?
