10 Speed Transmission Skips 2nd Gear?
TonyO
Calabogie Ontario
Ranger Lariat FX4
Have has my Ranger Lariat FX4 for two weeks now. I have just noticed the truck never goes into 2nd gear. From a stop the truck goes 1st to 3rd and revs fairly high before shifting but skips second. On braking truck drops from 3 to 1st. Has anyone else noticed this. This should be aproven transmission
MSG W
Kirk
Missouri
2019 Ford Ranger Lariat everything on it but Chrome Package
Yes I talked to the service manger he said it was normal, I also noticed that if go faster at take off it goes to second then third
I've had mine use second - usually when I'm accelerating fast - but usually it goes 1-3-5-6-7-8...
Beef_Stew
Aaron
USA
Also when in tow haul mode I notice my truck using 2nd gear
JoedOH
joe
ohio
Mine does the same if I drive it normal. If I give it more gas or use sport mode it uses 2. Nothing to worry about.
VAMike
2019 Ranger Lariat SuperCab
After a few thousand miles I see it use 2nd more often. (Then it skips 3 and goes to 4.)
Hounddog409
Tod
Ohio
F150
The transmission is designed to skip gears when load does not require it.
SubVet
Tom
Myrtle Beach
Even my Vette had skip shifting. There is an aftermarket module to eliminate the skipping of gears
EcoRanger
Doc
West By God Virginia
2019 Ranger XLT 301A SuperCrew 4X4 2015 Ecoboost Mustang 50 Year Appereance Package convertible
I always accelerate fast never noticed it
Fletch
El Cajon, CA
2019 Ford ranger
My experience has been, more and more, if you don't get an error code and the vehicle moves, the service manager will say it's behavior is normal.
doug910
Detroit, MI
'19 Ranger, '02 BMW 540i
It's just transmission shift strategies to get the best fuel economy for the given load. If you're in sport mode, it goes through all the gears all the time. In D, it'll skip gear and usually keep revs as low as possible. As long as you're not getting any consistent lurching or dramatic shifts, the transmission is normal.
