🎶Another one bites the dust🎶 (No accident, just time to move on)
Gizmokid2005
GA
gizmokid2005.com
SQL Developer
Welp, add me to the list of former 5G Ranger owners.
It seems that I've been on this plan of "drive for about 5 years or 80k miles per vehicle" since I started driving. I bought my '19 XLT in November 2019 with 34 miles on the clock. I traded it in at the beginning of the month after almost 6 years and just over 79k miles. The dealer gave me just shy of $19k on trade-in and allegedly sold it for around $20k almost a month later.
(Now allow me to wax poetic a bit until the end when I introduce the replacement.)
All things considered, I really enjoyed my Ranger for most things. It took me every place I asked it too, even places it shouldn't have, pulled everything I put behind it (including 8.5x20x7 enclosed trailers totaling 10k lbs loaded), carried multiple motorcycles home, moved cross-country, multiple road trips, plenty of dark sky/stargazing trips, full solar eclipse, camping, chasing cars through canyon roads, surprising people at how fast it is, and just generally from point A to B. Now it wasn't perfect, not by any means, I had my fair share of kinks to work out (and some that never got solved):
  • Rear brakes squealed multiple times, after the dealer pad slapped and turned rotors multiple times before 20k miles, I finally solved this by just putting my own rotors on it. Never had an issue again.
  • Rear driver's side axle seal failed around 21k, they noticed this during addressing the brakes at one of the visits. Warranty fixed.
  • Got a clunk from the rear, one of the upper shock mount bolts was loose, this was addressed at the axle seal visit under warranty, they just tightened the bolt.
  • Front rotors needed resurfacing and new pads at 29k miles. Had to cover $160 for labor for this.
  • EVAP core had a leak and was replaced at the same time the infamous blend door issue hit at 35k miles. All fixed under warranty.
  • Starting around 30k miles, I had an issue where my alignment would go out within about 5-8k miles regardless of driving, always the same way (wheel slightly off-center to the left), never addressed under warranty, was a persistent issue that seemed fine for the last 10k or so.
  • Developed a valvetrain rattle around 50k miles, between about 2500-3000 RPM under a moderate load you'd hear a rattle that sounded almost like the valves were starved of oil. 2 different trips to the dealer for this and the master tech swears it's "just the nature of the engine" and that nothing was wrong. I never had a catastrophic failure from it, and the issue persisted up until I got rid of it as well. I don't know if it's fine or not, it definitely doesn't *sound* fine to me but over 20k with the issue with no noticeable signs of issues from it.
  • At 60k miles I got hit with the infamous water in the spark plugs issue to the point it caused misfiring. I had to fight with the dealer and they had to fight with ford to cover this under my ESP, I paid for spark plugs and they warrantied one coil and the engine cover. Found out later that the dealer had to eat half the cost in the end for <reasons>.
  • From the time I brought the truck home, if it was cold enough the first time the truck tried to do the 1->3 or 2->4 skip shift, it would hesitate hard like it lost all gears before picking up the gear and operating normally after that. It had to be cold enough to trigger, which was hard living in CA and GA, so I never got this addressed since it couldn't be duplicated at the dealer.
  • In the last 10k miles it developed a slight shudder, sometimes, in 8th gear most noticeably, under a light load, but it was intermittent, so again similar issues with getting it to be reproducible for the dealer to address.
All of this said, aside from 2 different flat tires that I had a spare for, my truck never did leave me stranded or on the side of the road (or trail). I enjoyed most of the miles I put on it and overall it's a decent package. I had hoped that Ford would make some smarter decisions for the 6G Ranger than they did, they carried a few of the drawbacks from the 5G, I was looking at that as a potential upgrade path, however they left in the tiny gas tank (nothing over 20 gallons) and no split rear seat to name the 2 biggest ones for me.
Here's a couple shots from the Ranger's progression and final form.
Day after purchase:
Effectively final form (including powdercoated stock rims to lighten things up) in 2021 (during some of the fires in central cali):
Basically final "shoot" here in GA:
The time you've been waiting for, the new rig!
When I originally went looking I was just eyeballing what existed, considering new Broncos and F-150s both, depending on pricing and incentives, it was just time to keep an eye out with my ESP expiring in November (despite having over 50k miles left on it) and with the drivetrain issues I haven't solved yet I was trying to balance potential cost risks. A powerboost was enticing because of the absolutely abysmal power stability we have here now (we've lost power over 3 dozen times in less than 18 month's time), but I hadn't decided.
I wasn't looking at used, but they had a '22 F-150 Powerboost on the lot that was basically everything I wanted. 7.2kW pro-power, twin panel moonroof, crew cab, 6.5' bed (wasn't even looking for this, but a huge plus). ~33k miles, lease turn-in, certified pre-owned. It was hard to go wrong with a $45k price on a $74k sticker. I like to joke that I just watered the Ranger and it grew up 🤣
Upgrades are slowly in progress now!
It's been a great upgrade so far. I'm getting better mileage than the Ranger (despite weighing over 1k lbs more and being so much larger) and the space is like a friggin' apartment.
Here's to many more adventures to come! It's been real y'all!
-Gizmo
Nice upgrade Gizmo and ya sure you didn't get your Ranger caught in a rainstorm and it grew up? lol It seems many here are upgrading their Rangers now and many are going to the F150 which is understandable if you're needing more towing and comfort. The 7.2kW pro-power is an awesome feature and wish that the new Ranger had this option but maybe down the road. Hope this one treats you well and you have many more great adventures with it. Also stick around because you know damn well the F150 forum wo't compare to this one! :p
Gizmokid2005
Gizmokid2005
GA
gizmokid2005.com
SQL Developer
Nice looking F150. My son has a crew cab F150 and it feels like I could fit my entire truck inside his cab.
We've made this joke a few times too. They're just *SO* roomy.
I made that joke too! Feels very Gremlins given how close the packages and colors are! I had an '04 F-150 back in the day and this is even massive in comparison to that!
The 157" wheelbase is fun to get used to, it's like turning a bus compared to the Ranger 🤣
Would love to see a hybrid Ranger behind the 2.7, that could be a killer offering from Ford - I see *so* many Ranger work trucks these days.
Smart of you to stick with the correct color for a Ford Truck Blue!
Exactly! I *was* looking for the Antimatter blue, there's just something about how it looks in person that's mesmerizing, but if not, "Ford" blue is the only other proper option! (I would've also settled for Eruption Green...)
There's still "rumors" of a 2.7 hybrid Ranger and I'd love to see one( and buy one) but I'm not holding my breath it'll happen anytime soon.
The Ranger is now the size of my first F150 from back in 1996 when they did a complete redesign. I always loved them and had F150's for my business but they've just become do darn big for me now being retired for every day use. You can't beat the comfort level inside and 😂😂 at "turns like a bus". That's one nice thing about the Ranger, after driving an F150 it feels like a slot car racer. 😁
Gizmokid2005
Gizmokid2005
GA
gizmokid2005.com
SQL Developer
Yeah, outside of parking lots this thing is *way* better to drive than I expected. It's *SO* comfortable and it really holds on at speed too. I haven't really pushed it yet, but it'll come in time.
Chris M
Surprise, AZ
2021 Ranger XLT Sport 4X4
Security Supervisor
Day after purchase:
-Gizmo
It's beautiful and looks Incredibly comfy.
What engine does it come with that you can get better fuel mileage than from the Ranger?
Inquiring minds wanna know!
Nicely done. Enjoy!
rang19ca
Chuck
Carpinteria Ca
Retired Diesel Mechanic
Yes, @Gizmokid2005 You are doing the Blue crowd right. I'm still loving mine with only 26,000 miles on it. Remember the trip to Hungry Valley?
Gizmokid2005
Gizmokid2005
GA
gizmokid2005.com
SQL Developer
Nicely done. Enjoy!
It really is!
It's a powerboost, so the 3.5L ecoboost + EV motor/battery. I haven't yet done a hand calc, but computer puts me at over 23mpg on my first 700 mile tank. That includes a lot of city driving and a good bit of highway too. With the Ranger, my lifetime mileage is only 18mpg, and I have been sitting around 20mpg for my "typical" driving and could never even dream of almost 700 miles to the tank.
ppfd
2021 Tremor
RN/Paramedic
Your valve train rattle, I'd bet was the EGR piece that has its own long thread.
Mine was replaced about 2 years ago and needs it again.
I have one foot out the door as well. I'm paying my '21 off a year early as soon as this week. Interest was really good, so I wasn't in a rush.
I've been looking around for a replacement.
TxOTRRanger
Clay
Elwood, Texas
factory worker Tyson Foods
Congrats on the new ride dude! I had a couple of different F150s before getting my 22 Ranger. The last F150 I had my Dad bought from me after the Ranger came in. I like your old Ranger BTW!😎🤘
