will this support the juice i need??
The several thinner runs are likely individually terminated at each fuse, then out from the fuse to each relay. If this is the case, you are just fine. This makes the layout and manufacturing less expensive. No need to design-in/around a buss bar or other distribution block inside the unit. Curious if they used CCA - copper clad aluminum, or OFC - oxygen-free copper. For both, the shortest length is best.
yes that is what they did. all individual runs. im sure its cca. its a china hungchow brand lol. (auxbeam) i would be shocked if they put ofc in the device. one of the nicer ones like the trigger system is likely ofc.
so i finally for back around to this project tonight. got the old wiring out of the truck and cleaned up. now im looking at the wires closely they are 16 ga not 14 like i thought. it should be fine still but i wonder if im losing any brightness out of the lights from the cheapo wiring??
