Wheel specs for lift
viper94bite
missouri
2020 ranger
Sry if somewhere else, but I have not seen it.
I would like to lift my ranger, but all I have seen is recommendations for 20" wheels etc.
I'd would like to stick with a 17" if possible as I would rather have more sidewall then rim.
For example the rc 6" lift lists I believe 20x9?
What wheel specs are people running..backspacing, etc and have no clearance issues with?
Installing a lift is not hard, but I'd like to have wheels that work properly before committing and that's the part I'm not sure on is the wheels.
Have received no response from lift companies either.
I take it you haven't looked around much on here.... There are plenty of threads with information..... You need to search.....
NvrFinished
Shea
SoCal
2020 XLT 4x4 Rapid Red
More information is needed on how high the lift will be and what size tires you will run. The factory wheels have a +55mm offset. A +25 to +35mm offset for aftermarket wheels tends to work best without creating rub issues. Once you go lower than that, the wheel and tire combo begins sticking too far outboard. Removal or modification of the crash bars and possible fender trimming becomes necessary.
SGT
USA
2022 Ford Ranger
I currently run the RC 6" lift with the N3 struts. Because of the larger knuckle, they limit the wheel backspacing to no more than 6". If you do go that route, just be aware that the factory +55 offset rims will not work unless you run a substantial spacer.
There are calculators online that you can input wheel specs in and it will give you the numbers. Another thing to keep in mind, is that even if you push the rim size/backspace to the limit of 6", if your tires are larger/wider than what RC recommends, you may run into some problems.
If you like the big rim look, the company recommends a 305/55r20 (approx 33") on a 20x9 rim with +12 offset.
For my truck, I currently run 33x12.5s on a 17x8 rim with (0) offset. I also run the high clearance intrusion beams from Ready lift. I have lots of room with no rubbing at all.
Hope that helps!
viper94bite
missouri
2020 ranger
Hope that helps!
This is the kind of info I'm looking for. I've no interest in 20" rims, but 17s at most 18s. 33s are probably ideal realistically. Thank you.
I was considering a 4" RC lift that I thought was offered previously but only see a 6 now and the 3 ish one.
Which means I'll go 6.
Reactions: SGT
SGT
USA
2022 Ford Ranger
To be fair, looking at my current set up, I could easily fit a 34" or possibly even a 35" tire. While shopping for tires, I was really looking at getting a set of 285/75/17s. A little bit more narrow, but an inch taller. If you're looking at a set of rims with a lot of negative offset, I would stick with a 33". Don't forget to post pics if you do go with a 6".
Here
XLT
It will be a lot easier if you go check out the Showcase section of the forum. Each page of that section features pictures of 15 vehicles and lists some details including lift and tire size. Clicking on the image takes you to the owner’s showcase, where further details are listed, often including wheel and tire specs. The comments sections sometimes include information regarding what additional trimming, cutting, or modifications were needed to make the setup work for the owner.
CO2Ranger
285 70r17 17x8.5 +25 offset. Fox lift at out of the box height. Aftermarket crash bars required. Tread is even with the fender and the 8.5 width wheel along with the wider tire gives it a more planted feeling.
