Wheel spacers
Cupitt10
Dale
Sheffield
Ford Ranger 2022
Property developer
Hello, just fitted some 50mm wheels spacers on my 22 plate ranger. I’ve got 20 inch alloys on. But now the wheel catches when on full lock. Do I have to now lift the pick up ?‍♂?‍♂. Thanks Dale
Max Crafter
Max
Canada
Ranger
probably.
search around for the calculators to determine wheel offsets.
at the very least you may have to modify/remove your crash bars. Some people are OK with that, others arent'
I get the ease of adding spacers to push the wheels out to a more aggressive stance, but they arent my favorite way to accomplish that for numerous reasons. Especially 2"
awd.nv
Anthony
Las Vegas, NV
'21 Ranger XLT Tremor
Computers
Maybe see if high clearance intrusion bars will help where they run or if you just want to remove them.
You might get lucky if you crack them loose and push them away from the tire, then tighten them. Might do the trick if it is just barely touching.
AndyMedic
Andy
Paramedic
Also what offset are your wheels?
Cupitt10
Dale
Sheffield
Ford Ranger 2022
Property developer
Not sure what offset is at minute but looking at it. I think it will either need lifting or spacers less than 50mm. Might just lift it 2 inch. It does stand well though with the spacers on ?
