FULLSCALE
Adam
Ontario, Canada
Cleaned windows, installed new wiper blades, took off EcoBoost badge, cleaned throttle body and catch can. Tomorrow interior then gonna pull the wheels off for the pre salt detail
How many miles? That throttle body looks pretty oily!
Roofhopper
Ted
Fairfield OH
2019 Ford Ranger XLT FX4
HVAC Service Manager
Doc
Doc
Live oak fla
I should note that this is the first time I’ve pulled throttle body to clean since truck was new and have only had the catch can on for about 500-600 miles. Truck currently at 12,500 miles, and there was an equal amount of oil in catch can as what I wiped off throttle blade
You need to run s mode for a while and keep the rpms up and burn some of that richness off.
Regards
Roofhopper
Ted
Fairfield OH
Thanks. I’d be curious to see how much oil is on the throttle body after you get some more miles on it again.
Next planned inspection will be @20k, will update along with catch can findings
Roofhopper
Ted
Fairfield OH
Regards
I do probably 10% of the time that I’m driving and am not bashful about letting the Ranger eat, also running 93 octane
Doc
Doc
Live oak fla
Maybe a Dyno is in order? No tune just to see what’s what...
Regards
Roofhopper
Ted
Fairfield OH
Regards
In the plans for this winter when work settles down, along with charge pipes and hopefully maybe an intercooler :fingerscrossed:
Doc
Doc
Live oak fla
That’s a lot of blow by...how many miles did you have before your first oil change ?
Roofhopper
Ted
Fairfield OH
Oil at dealer every 5K
Doc
Doc
Live oak fla
In my little mind....(I’m a motorcycle drag racer retired) we would build an engine and add break in oil , and do a Dyno cold run...drain the oil refill with lucas break in oil, run up and down rpms for 300 miles, then Dyno hot run. always some metal specs in oil after both runs...then change oil again Mobil 1. ...I did a moderate break in on my ranger, at 1000 miles, I changed the oil, cut the filter in half, and behold...metal particles. Changed it again @ about 2000 miles and no particles. So the moral of the story is...up to you! Been to the Drag Strip once and will go again once the the ambient temp is below 70 degrees.
Regards
Roofhopper
Ted
Fairfield OH
I initially wanted to do 1k miles but the service manager assured me 5K was fine, seems excessive from growing up on flat tappet cams but we’ll see what happens... Dealer made me pretty confident about the decision though, and are cool with some mild mods without voiding my engine warranty
Rp930
Denver
ā€˜19 Ford Ranger Lariat, ā€˜23 Macan,’21 Shelby GT500
I changed at 1000. Just couldn’t leave it. Using Mobil 1 so now I’m curious what the throttle body will look like. I pretty much baby it.
