What’s this noise?
Joeiconic
2021 Ranger XLT
Any thoughts on what this squeaking noise may be? I seem to notice it more at slower speeds and it seems to be from the right side. I don’t feel or notice any issues with drivability.
Jason B
Louisiana
2021 XL STX SE 4x2
machinist
If 4WD, may be a bad CV joint on front axle.
4WD or RWD, may be a bad wheel bearing.
Joeiconic
Joeiconic
2021 Ranger XLT
I don’t know, the videos of cv axle and bearing noises dont sound like this. The comparable “noise” videos I could find are for vehicles with worn out bushings, such as motor mounts (apparently common in Tacomas), shock mounts, or even a radiator mount. I‘ll see If my local shop can chase it down.
By the (Tone) it sounds more like a (Thin Metal) resonance - so either the brake pad clips or the back plate - rubbing against the rotor - possible small pebble caught in between backplate and rotor.
I would check that first as a possibility
This was my thought as well. Easy to check.
Grandaccess
Robert
Binghamton, N.Y
2021 Ford Ranger XLT FX4
Computer Consultant
OMG how do you deal with that noise, turn the radio up!
