Wet drivers floor
Mark saulys
Hawaii
2019 ford ranger
2019 ranger, driver side floor was soaked, dried it all out, hit the outside with a hose cannot find a leak anywhere, tried all the usual, ac drain , windshield, door frame, gave it a pretty good hose down, and no leaking anywhere, anybody with any ideas of what to look for, thanks
Ace
Ace
Raleigh, NC
2021 Ford Ranger
Just a thought but do you have an after market window visor installed? I noticed on mine that my driver side front floor board was wet after a thunderstorm but luckily my rubber floor mat caught most of the water. Didn't think nothing of it until I noticed that there was rain water coming in from the top of the window and dripping onto the floor board. I have an in channel window visor. So I then removed, cleaned, and re-installed it with a new 3m double sided tape and it seem to have fixed it. Had another storm last night and haven't noticed a leak.
BGDOGY
Tommy
virginia
2019 Ford Ranger Lariat 4x4 crew cab
Check the seal on your back window, my 2019 was leaking from there and the water ran down and then along the driver's side all the way to the front, didn't notice it until I removed my floor mats to vacuum under them.
Mark saulys
Hawaii
2019 ford ranger
I actually do have the in channel visor that I installed months ago, I did wonder about that, I’ll try blasting them with water again, thanks
Mr. Yuck
Hilo, HI
XLT FX4
What was the ultimate cause. I get wet floors on both sides and the dealership basically is telling me that I need to find the leak and not them.....
Muscleford
George
Ohio north coast
Retired CFO
At you need to do is find another dealership.
Mark saulys
Hawaii
2019 ford ranger
I went to ford dealer,over 800$,four day car rental and came home with the same leak, I think I found it now , attached a hose to step ladder and sprayed the windshield for about a hour and found water leaking down the inside fire wall, driver side behind the carpeting
Reacher19
Westlake Florida
2019 Ford ranger XLT supercrew
Hey Mark
I have the same issue with water on my driver's side floor. Sprayed down truck and can't find the leak. I was wondering about my windshield also because the edge looks strange. How did you end up fixing your leak?
