Well bummer for me
Russd
jeff
Arizona
Vw bus 4runner
Installed a light bar behind the grill and wired it up. No power coming from the switches. Did a quick check of the fuses and they don’t have power either.
Did some wiggling and what not of the relays .. nothing. Tomorrow I’ll check that high current fuse block to see if I have the 100 amp fuse.
Any other tips? Would hate to go to the dealer but..
Maybe Sid @Msfitoy can help you out. He's pretty knowledgeable when it comes to lights and wiring. He has enough lights on his Ranger to power up a small city so I'm sure he should be able to help you out.
Phil_R
2024 Ford F150 STX
Retired for now!
I believe that you are talking about the Tremor Upfitter switches. I wired up a light bar and ditch lights and mine worked fine. Be sure you have a good ground when checking for +12VDC. Let us know how you come out and what problem is found. Good luck and thanks!
Love to help but need more precise details...I'm not familiar with Tremor's switch setup...I run all of my lighting power mostly through Trigger 6 with exception of fogs which are using the factory power supply...
Russd
Russd
jeff
Arizona
Vw bus 4runner
So the tremor has these 6 pre wired switches. Fused with relays. Should be hot, just add a ground. None of my wires, fuses have power. I’ll look into it more later today.
Russd
Russd
jeff
Arizona
Vw bus 4runner
Welcome to the missing fuse club?. Guess I’ll give the dealer a call today. I just dislike going there. Last time I went there for an alignment after installing front spacers they left this mess.
Other option would be to just run power to the tremor switch fuse block myself. ??
GearHd6
Connecticut
Ram 2500
That open slot is where the switches get power? It seems it's missing more than a fuse, I don't even see the wire that should go to it.
Russd
Russd
jeff
Arizona
Vw bus 4runner
Supposed to have this fuse on the right. I don’t set what it would connect to on the bottom side. There is nothing there.
Russd
Russd
jeff
Arizona
Vw bus 4runner
It has a bus bar on top you can’t really see in my picture but yeah I don’t see anything on the bottom to attach to.
bfastr
Nashville
2021 Ranger Lariat
I would be PISSED. hell I am pissed and its not even my truck. AAAAARRRGGGHHHH
I gotta re-tell my fav dealer story. the wife likes getting her oil changed at the Quick Lane ( I do not).
last time we were picking it up a customer comes running in sweating and mad, says "you just rotated my tires and the front wheel fell off" guy at the counter says " well bring it back and we will fix it" the guy says, " the truck or the tire?, because they are both blocking the intersection up the way. did you hear me? the truck is MISSING A WHEEL, IT F'ing FELL OFF"
very entertaining to watch the scramble after that.
Russd
Russd
jeff
Arizona
Vw bus 4runner
Trucks going in July 8th. I’ll update in the future.
awd.nv
Anthony
Las Vegas, NV
'21 Ranger XLT Tremor
Computers
Yeah I was gonna say, sounds like a warranty issue. What year Tremor is yours? I am gonna check mine tomorrow. Curious if your interior switches light up when the truck is on if you put them into the on position? Planning on adding some lights this fall and do not want a surprise when I am doing it (who knows how long parts would take to arrive from Ford if needed).
