Weird Low-Speed 4x4
M@nd0
Detroit, MI
2019 Ford Ranger- Lariat (SuperCrew, 501A, FX4, Black Appear., Trailer)
Hey all, just got my ranger a few weeks ago and I was testing out all the features when I noticed something strange. I was in my work parking lot with the 4H on just making sure it works properly (in "normal" mode for those with the TM system like myself), and was making a low-speed turn in order to back into a parking space. The truck seem to have come to a jerking-like halt, almost as if the tire was rubbing on the inside, or outside, of the fender. I'm not knowledgeable enough to know if this is some advanced system with the 4x4, especially since I do not run into this issue when I'm in 2H, that causes this. Just curious if anybody else has run into the same issue, or knows whether it's truck doing some computer-magic.
Thanks in advance!
M@nd0
M@nd0
Detroit, MI
You shouldn’t be turning the truck in 4x4 on any surface that isn’t slippery. Your binding up the drivetrain. Simple 4x4 basics
Ahhh, okay, like a said I'm a n00b, first truck. Thanks for the heads up!
Anthony
Anthony
Connecticut
COO
That is correct, putting it 4X4 on non-slippery / non-loose surfaces can break things.
A bit more technical info on that: http://www.4x4abc.com/4WD101/def_turnpart.html
It causes mechanical components to bind instead of moving freely - this situation is called "axle binding" ,"driveline binding" or "driveline wind up". First indicators while driving is a hard steering feel and the vehicle displaying jerky movement. Shifting back to 2WD will become impossible (gears and levers are extremely forced together). Continued 4WD use on dry surfaces will cause the weakest links to break (U-Joints, axles, differential gears, transfer case gears and chains, bearings, drive shafts).
Anthony
Anthony
Connecticut
COO
And don’t get anxiety over breaking anything from what you’ve done. I’ve accidentally bumped the 4WD knob into 4H in mine a few times and it’s no worse for the wear. Enjoy your truck!
Thanks in advance!
Hi M@nd0
You just experienced drivetrain bounding up on on a concrete or asphalt surface. The vehicle comes to a halt. You are not hurting anythng, but It is not a good idea on a high contact surface to use 4H. If this was an AWD vehicle, you would not feel this at all. Ranger Pride is a bit over the top but his lesson learned is do not do this on a regular basis as something in the drivetrain will cry uncle... The way to use a 4x4 is to gain experiece, but for leaning, use 4x2 until it does not work Then switch to 4x4H. For the tough conditions, select 4x4low. Thing we taught at Ford in the Advanced Off Road course was to take it slow... 4x4ing is not racing, Slow is the operative word. Slow will not likely hurt anything, like slowing backing into the parking space.
M@nd0
M@nd0
Detroit, MI
Hi M@nd0
Good to know! Thanks for the knowledge and experience!
