Low speed hesitancy...
pwrplay
Ontario, Canada
2019 Ford Ranger XLT Sport
Yes, I know this subject is not new and I have seen many posting around this subject. But every one is different and doesn't quite fit my truck's behavior. As many of you know, I have one of the highest mileage 5G here (90K) and she's been just about perfect in every aspect. Lately, I've noticed a peculiar behavior after starting my truck (cold or hot). When I put her in gear and creep off standstill (1-2mph) to maneuver around parking lot or my driveway, the throttle hesitates as if like a switch turning on and off. This makes it very difficult to drive slowly. If I put more gas in, everything is ok but I'm going faster than desired. After driving for a few minutes, starting off a stop will be normal again. If I shut it off and immediately drive off slowly, same hesitation occurs. According to all the other posting about hesitancy, is this pointing out to a failing injector(s)? Confused...
I just came across this thread whilst searching for info on a similar issue I am noticing with my Ranger. Did you happen to figure out what the issue is/was?
I did...basically, I sprayed carb cleaner into the throttle body to free up built up residue that was causing the butterfly to stick and causing hesitation...it went away after several applications of Gumout...it will cause "misfire" reads so be prepared to clear the codes after...
https://www.ranger5g.com/forum/threads/project-msfitoy-v3-0.2804/post-432705
pwrplay
Ontario, Canada
Thanks, I'll keep that in mind if it gets worse. It doesn't seem to happen all the time right now.
