Weak airflow when combined vents are turned on
Smc915
Shawn
Mentor ohio
Ranger 19
Is anybody else having this problem?? I have little to no airflow out of the vents if I combine the bottom and middle vents. But a lot of airflow If I do one or the other. I’m not having any other hvac problems besides the passenger vents get a lot colder air than the driver vents
BS67
Brian
Nebraska
2022 Ranger XLT
Have you tried changing the cabin air filter?
Smc915
Shawn
Mentor ohio
Ranger 19
No I’ll have to look at that. Wouldn’t that affect all the vents?
BS67
Brian
Nebraska
2022 Ranger XLT
A plugged cabin air filter would. Take it out and blow it out. Check for any little critters that might have crawled in there to nest. Put the filter back in and see if your air flow improved. Worth a shot!
Vitis805
Santa Barbara County, CA
2019 Ranger XL
Wine Nerd
Same thing here. When using both upper and lower vents the airflow is weaker than just using upper or just using lower. I figured it was natural. It is definitely not a clogged filter in my case. Waiting for others to chime in.
HarryManback
New England
2021 Ranger XLT Tremor
Electrical Engineer
Mines always been like that
Reactions: EJH
halligan1201
Byron, IL
2020 Ranger
Emergency Management
What about the ac? I feel the passenger ac is freezer cold and the driver is just a 70* breeze even on max ac
Do you have dual zone? Mine does that when they're set at different temps.
Smc915
Shawn
Mentor ohio
Ranger 19
yes.
Yes But max ac puts both temps at low and recirc and max flow. Still passenger gets colder air than driver
Fritz
St.Paul
2019 XL
I have the same problem with my base xl.
Fordup
Ed
NY
youtube.com
Retired YouTube Creator
Same thing with my Lariat. Have to keep the fan on 4 with bottom and dash vents turned on to keep it cool when heading into the sun. That big black dash holds a lot of heat when the sun hits it directly.
FerdRanger
Ferdinand the Great
Central NY
2020 Ranger Lariat Sport 4x4
no thanks
try the sequence you turn on combined vents
first the lower and then the middle might be different than vice versus
try both ways
mine matters… but won’t be equal
Smc915
Shawn
Mentor ohio
Ranger 19
the fan moves air at a certain cfpm.
so imagine if you had one outlet from a fan pushing 100 cfpm
you can expect 100 cfpm coming out of that one vent
open 2....you can expect 50 cfpm each
open 10 you can expect 10 cfpm each
the outlet is the same cumulatively at 100 cfpm, but each individual vent drops in volume.
the more exits you have, its obvious the volume of air will feel less .
When I say reduced air. I mean the air compared to one vent is extreme. I’m getting literally little to no air on both vents bro. It’s hard to explain but I feel I should be getting more pressure
Dereku
Chicagoland Area
I have the same issue from day one. Im a big fan of feet and face. Im used to reduced flow but this is bad. If i do not select anything and let it do auto it is a better balance. Just odd. And to the 100cfm flow idea, its not 50/50 its like 20/20 and the other 60 is lost.
