USB port and voltage meter gai
ManOfH2o
Will
Gulf Breeze, FL
2020 Ford Ranger XL Supercrew
Safety Director
I installed a USB and voltage meter plug today. I was wondering something when I cut the keys off the voltage meter is still on, so is that going to run my battery down.
TimmyB
Timothy
Sarasota FL
2021 Ranger Tremor, 2020 Fleetwood Bounder 35P
Our resident retired Ford engineer Phil Schilke has commented on another thread about the outlets timing out after two hours. I wish I could remember what thread that was. I believe it was a question about 4-down towing and using the 12V for the toad brake without direct power from the battery.
ManOfH2o
ManOfH2o
Will
Gulf Breeze, FL
Safety Director
I think ? it did because I came back out about 2 hours and the light was off.
JKocot
Montpelier, VA
2020 Ranger Lariat SCrew FX4, 2018 Explorer Sport
Senior Systems Engineer/Former Marine
I installed the same thing today. Went back out a little over a hour later and it was off. Pretty sure it is 75 minutes before it shuts off.
ManOfH2o
ManOfH2o
Will
Gulf Breeze, FL
Safety Director
I installed the same thing today. Went back out a little over a hour later and it was off. Pretty sure it is a 75 minutes before it shuts off.
Thanks ? Dude
Adventure Ranger
Saskatchewan, Canada
2020 Ford Ranger Lariate Crew Cab FX4 Sport
Heavy Equipment / Truck shop Foreman
Adventure Ranger
The time can be adjusted with ForSCAN if you want to.
ManOfH2o
ManOfH2o
Will
Gulf Breeze, FL
Safety Director
I got it off of Amazon
TimmyB
Timothy
Sarasota FL
Do you know what the maximum time setting is? This could mean I don't have to run a separate plug in for my toad brake system.
Hi Timothy,
Yep....I ran directly from the battery to the Add-A-Brake to avoid the time out issue as I will not being doing any Forscan adjustments. Works for me and we have 2000 miles of towing the Ranger behind the RV with no problems...
best,
