Upgraded from mono leafs with Fox 2.0 to OME 1.7 multi leafs.... OMFG
jflogerzi
Moreno Valley, CA
Fox 2.0 coil overs so the front is raised/leveled. The OME are 1.7in lift so the rear is back higher again. That’s fine cause I tow a lot. Once I get my trailer connected and fully loaded I’ll level the front out (adjust the coil overs).
those can't be adjustable while on the truck IRC..
fusseli
EE
I'm installing my ICON rear leaf springs this weekend and have purchased new poly bushings from SuperPro to put in the rear eye. I will have to reuse the inner sleeve on the OE bushings for my new poly set
Question for you, how difficult was it to remove the rear bushings from the OE spring? Any advice on method? Since my truck will be out of commission I won't be able to go out and easily get tools and I worry that removing that bushing will be a headache. Thanks!
if I recall, they slide right off with some convincing to move the old rubber
TxOTRRanger
Clay
Elwood, Texas
factory worker Tyson Foods
I like reading and seeing what ya'll are doing with your trucks and what you are towing with them. I didn't order mine with a towing package, now I'm wishing I had ordered the towing package. Mental mistake! Lol🙂
