Updates to Transmission
Hurricayne
Louis
Denver
2019 ford ranger Lariat
Is there a way, besides visiting a dealership, to check the software/firmware version on my 2019 Ranger? I want to ensure I have the latest updates for my transmission.
I have Forscan and have already updated Sync 3 via USB from Ford's website, but I assume Sync isn’t related to control modules.
My modem works, and I have 3 months of free Wi-Fi. Will updates for the PCM and control modules come over the air, or do I need a tech? Any tips on checking versions, the best updates for engine/transmission control modules, and how to get them?
Forscan wil show you - current calibration levels etc for the PCM, however you will need FDRS (Ford Software) and a Expensive (Passthrough) J-2534 capable adapter to perform any updates or scan for updates. The cheapest cable adapter is the Mongoose Plus @ $540.00 and then you will need FDRS or a high-end scan tool to actually perform any software updates and logged into a ford account for access.
So, depending on what you want to spend - Dealer is the best option, unless you already have the proper tooling.
RangerBill
PA
You won't be able to update the PCM over the air. The PCM controls the transmission.
Hurricayne
Hurricayne
Louis
Denver
Bummer - I have an appointment with a dealership for 2 recalls, so ill ask them to double check while my truck is in there
