Fish
- First Name
- Roger
- Joined
- Mar 20, 2019
- Threads
- 2
- Messages
- 58
- Reaction score
- 64
- Location
- Hershey, PA
- Vehicle(s)
- 2019 FORD Ranger Lariat Hot Pepper Red, 1993 F-150 XLT
- Occupation
- HVACR
- Vehicle Showcase
- 1
Hi Rich, Yes I think what ur saying is correct but I'm not familiar with the Ford Perf. intake or tune. I installed the Roush CAI which they use fords filter box and supply snorkel but replace the box cover, add cone filter and the feed line down to the blower. Claiming to 21% more air flow. Then they prefer that a Ford dealership does the flash for loading the tune. I should be getting the Roush tune loaded this coming week so we will c how that goes. As for the 3yr/36,000 warranty, that starts from when the vehicle was delivered not from when the Roush Level 1 was installed. Owner needs to send warranty paperwork into Roush after install and from talking to them, if something does go wrong and u need 2 use, it sounds like they provide $7500 engine related, $2000 for trans/rear related repair. Roush is showing their final dyno numbers after using 93 octane, the CAI and their tune as being 275 rwhp and 339 rwtq so using my estimated numbers, I'm guessing that would be 295 to 305 engine hp and 360 to 370 engine torq. @ the crank. You would have 2 compare that 2 the specs Ford Performance is showing. That's the extent that I know.So does this mean the net results of the Roush and the Ford are roughly the same? I can't read the numbers on the plots of the Ford tune on the cut sheet. Another thing is that if the Ranger "kit" is like that for the Mustang you get a drop in filter which is probably essentially like or is a K/N, while the Roush has the chamber and the cone shaped filter like more traditional cold air set ups? If the net increase is about the same and both have the same warranty, then I'd opted for the Roush....at least in absence of additional information that we hopefully amass before the Ford comes out. And I don't know that we have anyone posting that has actually done the Roush mod?
