Dereku
- First Name
- Derek
- Joined
- May 18, 2022
- Threads
- 31
- Messages
- 2,813
- Reaction score
- 6,894
- Location
- Chicagoland Area
- Vehicle(s)
- 2021 Ford Ranger
- Occupation
- Project Manager
You will most definitely notice any rolling weight you add. I have done it to many vehicles in the past. The turbo will help to a greater margin but the difference will be there.Do you notice the added weight when driving?
I've been looking at aftermarket rims and tires. Both add weight so I was curious about the weight of stock tremor wheels. Seems the rims are quite a bit lighter than even the lightest aftermarket rims, which I've seen to be around 27 lbs, give or take, but generally, most are quite a bit heavier. General's aren't the lightest tire so if I went with a Tremor rim and one of the lighter tires - Toyo and a few others, I can keep the tire weight in the low 40's for a combined weight in the range of 67-70 lbs which is pretty respectable. Glad I know the Tremor rim weight now, but yes, Hankook's at 35 lbs is about as light as it gets for tires so I'd be adding roughly 7 lbs of unsprung mass.
