Tremor suspension components
tygr2007
Tyler
Naples, FL
www.tradewindnaples.com
Designer @ Tradewind Designs
Can you tell me a little bit about the rangers power with 35s on it. Do u have a tune. If so which one?
I have a bdx tuner with a 93 performance tune. Truck can jump and spin all 4 wheels in 4wd for a few seconds in dry conditions. Don’t even get me started when it’s wet, it’s a drift truck.
0-60 around 6 seconds which isn’t bad for 35’s. Smaller wheels im sure it would be faster 35s just weight a LOT. It always surprises me how fast it gets up to 120
Fz icy
south carolina
2021 ford ranger tremor
Any lift kit should work on a tremor, as the only difference in parts between a tremor and non tremor is the coilovers, leaf springs and rear shocks.
Edit: lift kit suppliers added the dosn't fit tremors because they didn't know if they would work till they fitted it themselves. Then this was never updated.
So will rc work as well or just all of the bds
tygr2007
Tyler
Naples, FL
Rough Country will work, however I highly suggest going the BDS route as they offer (in my opinion, I’m not sponsored) higher quality parts, unlimited lifetime warranty, and an INSANE “You break it, we’ll replace it policy.” The amount of parts that I have smashed, dented, etc- and they have sent me… probably would’ve added up to another lift kit entirely. Also, you can keep your Tremor rear shocks they’ll work with the kit.
Fz icy
south carolina
Okay thank you. I know bds is probably the smarter decision but I’ll probably still end up going with rc (on a budget). So just to be sure the rc 6 in lift will work on my 2021 ford ranger tremor
OGMix376
Bryan
Steel knuckles on the tremors..
You can easily tell because they’re painted black..
OGMix376
Bryan
Yes, I got the cheaper one with spacers. Ain't nobody got money for that expensive shit. My setup is a bit unique, I have a spacer stack up front. 3" from fordrangerlifts.com and then the BDS 6" spacer. All that on top of the tremor coil which gives about a 1" lift from FX4.
I'm totaled around 9-10 inches up front while the rear is up 6" from stock. I'm leaning back a little bit, the front is about an inch taller than the rear. I feel like this corrects some of the slanted body lines and gives the truck a much bigger look.
I went the BDS 6” lift coilovers route.
I have 34.5’s
Pretty happy with how it turned out…
My front skid plate is now installed😅..
This picture was taken before I put it back on.
