Too much load? Let me know!
Wesmertz
Wesley
Utah
2021 Ford Ranger SXT FX4 Crew Cab
Grocery Management
Tomorrow I’m heading on an hour and a half trip from 2800ft elevation up to 10500ft elevation. I just bought this Mahindra Roxor and it weighs 3000lbs. The trailer weighs by my research about 2000-2200lbs. So trailer weight about 5200lbs tops. Plus probably about 500lbs of stuff in the truck between my wife, me, tools coolers, camping stuff etc.. The way it’s loaded right now I’ve got about an index finger width of clearance between the spring and the bump stop on the back of my truck. Should I haul this way or should I shift the machine to pull weight back or move it forward? To me the truck and trailer look level and there’s definitely more weight in the tongue than the back of the trailer.
KNI
Finland
Ranger Raptor 2021
Well the Ranger can legally tow about 7700lbs (3500kg) so no issue there. Tongue weight max is about 10% of tow so 770lbs. Looking at the rear sag that may be on bit higher side but I don't see a problem there.
Move the load an 1-2 inch back if you want to be safe.
Note: Not a professional answer, just your random farmer answer based on looking at a picture. Always check your car specific details and manual.
awd.nv
Anthony
Las Vegas, NV
'21 Ranger XLT Tremor
Computers
I would expect no issues, there are people here towing +5000lb travel trailers and that is basically a parachute behind you. I tow 4000lb travel trailer + payload with zero issues. Been to Brian Head, UT towing and was no problem either. Just one very steep part going up hwy 143 but power was not an issue, the trans hit like 250F but cooled quickly afterwards.
This is what I was talking about
https://maps.app.goo.gl/AU8CPYACbrhK7SHg6
Wesmertz
Wesmertz
Wesley
Utah
Grocery Management
That’s my trip right there. I’m going from St. George to Brian Head. Gonna do some bike riding and ride some trails on the Roxor in one of the prettiest areas of the state. I’ve been assured my situation is good. I know the towing capacity is well under factory recommendation. Motor can handle it. I just get concerned about how the load is sitting. I know there’s an ideal balance. Just not sure how to exactly figure it without scales.
mtbikernate
NC
2019 Ranger XLT 4x4
you kinda need scales to be 100% certain about your load balance.
I'm not thrilled with how the front of the truck sits a touch higher than the rear (though I've seen MUCH worse), but you leveled your Ranger, didn't you? pretty sure the only way you can get that part of your tow any better would be to use a WDH. trailer itself looks pretty level (hard to say much better given the tilt/slope in the pic), so that's good.
Dieseldean1
Reno
2020 Ranger
About the same weight as I pull- no problem.
Expect to see single-digit mpg.
great power, lousy mileage.
NICE HOUSE!!!
LawnMM
Rich
'23 Ranger Tremor
If it's not already evident, people are asking because the Rangers brakes can handle about 3500lbs of tow load by themselves.
If you're going to do the max tow load of 7000/7700 whatever it is the trailer needs it's own brakes and your truck needs a brake controller.
Especially going up and down 10k high Mountain passes.
Wesmertz
Wesmertz
Wesley
Utah
Grocery Management
We made it! She never went over 3500 rpms. Now we’re cruising around the mountain in the Roxor. A nice change being that it’s 110 at home, and 66 degrees up on top of the mountain!
awd.nv
Anthony
Las Vegas, NV
Computers
Man, I am totally jealous right now. Congrats on the safe tow.
I'm trying to figure out why your questioning if your vehicle can tell that amount of weight when it's clearly within the factory tow capacity. When will people stop asking this question?
rydfree
Benny
Maintenance
Well you can tow #7500 the right way or the wrong way. I think he was asking how to do it correctly. It's always nice to help someone that may have never towed before. I've seen a lot of scary stuff on the road. Just last week I saw a Dodge Ram towing a heavy Kubota zero turn mower that was loaded all the way to the rear of a 12' trailer. He had all his trimmers and light stuff at the front .That thing was swaying all over the lane.
