Taboo Tranny Talk
moorejl57
Jamie
Corvallis Oregon
2021 Ranger Lariat FX4, 501A, fully damped
Try driving in tow mode, as I believe that it will not skip gears. It's the first switch I hit after starting the truck.
To save on daycare, get one of these. Just be sure to leave food and water.
Putting a TV in it will keep the little ones busy.
I am thinking you could raise chickens in that and live off selling the eggs!
Just got back from a drive after reading this. Most probably the fan you are hearing. It quiets down after 3rd. And the fan queits down after a few minutes.
Now my transmission does shift a little funky until it warms up after a minute or 2, so I usually start it and let it run for a minute before backing out of the drive. It's gotten better since miles have been added on.
I kind of enjoy crawling slowly through the neighborhood with the fan loudly reving.
A good test is to jump in start it up and sit inside for a minute and listen to the fan until it quiets down then start your trip. See if you hear the same and it shifts the same.
What fan noise? I have an engine cover ...
Nope, not gonna convince me I need something else. Not listening…lalalalalalalalala
The hood side weather stripping probably does reduce exterior noise a tiny bit. More than the engine cover (which does nothing for the cooling fan clutch). The mouse family under the cover dampens the engine noise.
Edit: forgot to mention the plugs for the hood holes to dampen sound ...
Dereku
Derek
Chicagoland Area
2021 Ford Ranger
Project Manager
Hood hole plugs? I must have these now. More air flow for my filter. Less hood stealing air holes.
