Swaybar removal
In all seriousness to a bit of an odd thread. If you are so serious as to talk about tiny spares (dump the spare, just get a Triple AAA card or plug kit) and using Helium, which would leak out fairly quickly, then I'd suggest doing some aerodynamic skinning. Such as this under engine example:
Or more extreme like this:
Bed mods, maybe not as extreme as above, small spoilers, and the wheel covers could yield some very slight improvements.
Lowering the truck and, as stated above, weight - that's possible.
Weight is a big thing because the shape isn't aerodynamic and it takes energy to move weight:
F=ma
Because of the tremendous air friction, you're constantly accelerating when driving forward. I don't mean like stepping on it, I mean in maintaining your speed, you constantly have to "literally" pour in more energy.
Every pound reduced will increase efficiency. Whether that's losing 50 pounds yourself, or taking out the spare. The few grams of helium vs. atmospheric air is last in your list of mods.
Nitrogen is used, with much better success and has a few things going for it. First, it has less friction with itself inside a tire. So rotational momentum is helped in an MPG-focused discussion. Also, Nitrogen leaks out less than normal air and tire pressure is better maintained.
One poorly inflated tire can throw away MPG like mad.
A smaller and narrower tire that is lighter and properly inflated can make a measurable difference. But getting to that ideal inflation state is more than what the door sill says and I don't know how a layperson could ever get it 100% optimal.
At the end of the day, the Ford Ranger isn't built to get good MPG. My little 2005 Scion got 38 MPG and my 2022 Ranger gets 17, despite years of design and engineering improvements.
Wanna haul a bunch of dirt or pull a trailer, then get a Ranger.
Want good mileage? Know that the options are limited and extreme.
Good luck and let us know what you do and the results you get, that'll get the positive attention of most of us.
I suggest loading the bed down with around 1500 lbs of assorted weight, load the cab up, and lower the air pressure in all 4 tires to :crackup:around 20 psi.
Obviously this will lower the total profile of your Ranger thus presenting less resistance to the wind.
Another option to lower your Ranger would be to get 4 of those itty bitty Prius donut spares and mount them on your Ranger...this will have the affect of not only lowering the truck for less resistance, but also get rid of some of that "truckish" unsprung weight.....
Hethern
Jay
Shallowater, Tx
2020 Race Red Ranger
Communications Technician aka (Phone Man)
You're driving a Tremor around and you're going to get rid of the full size spare so you can put a spare from a Prius on it ... for better gas mileage?!
You should be beaten with a rubber hose in an alley. You're driving a truck man! It's for truck things! If you want to priss around getting 40mpg trade it in for another Prius because if you think 30lbs of tire and another 4lbs of sway bar are going to do anything for your mileage you're kidding yourself.
Just enjoy your truck buddy, put the pedal down and ignore the mileage, that's not what these vehicles are about.
Exactly!!
NerkyMohawk
Nick
2023 Ford Ranger Tremor Lariat
F&B Manager
I wish I would have snagged a pair of the disconnects before he stopped making them. The guy traded his Ranger in shortly after.
I wished he sold 1/2 set...$200 plus was out of my budget at the time...you only need one disconnect to completely disable the sway bar...
NerkyMohawk
Nick
F&B Manager
Yeah $200 was steep and I had just made some other purchases for the truck so I couldn't snag them at the time. Pretty sure he only did one batch of them and only sold them for a couple months.
I've looked at using other options but it's similar price point and I would still need to modify parts. If I didn't drive the truck like I stole it I'd consider just removing the sway bar completely.
Grandaccess
Binghamton, N.Y
Computer Consultant
Can someone help me with my question or are we just here to fart around?
I run my tires at 41psi and I manage 18MPG on average being 5100lbs me the dog and a 1/2 tank on 285/75 and Hwy not towing I can get as much as 22mpg, if you want any more.... get a Prius?
having bought a midsize truck you knew what you were in for? Name one Truck on the market that gets better MPG?
you are new here aint ya....
Based on the quality of the question (try not to sound like a starbucks soy boi), in between Farting around you have guys here that could rebuild these 5Gs in their sleep, 10 times better then any ford dealership in the country ....
KJRR
KJ
Cleveland, OH
Professional Curmudgeon
I'm just here for this...
Robert T
2023 Ford Ranger Lariat
Air Force Retired
I don't recall which post I made...what I've come to understand is 5G Ranger varies wildly depending on trim...2wd wins MPG every time with high 20s...4wd/FX4/Tremors probably lower 20s if left stock...there's no way around this due to larger AT tires, added driveline weight and friction...leveling is the MPG killer...raising the front of the truck allows more underbody aero drag...
My case is text book on how to kill MPG:
1-2.5" front level
2-1" rear lift
3-wider flares
4-285 tires with spacers
5-quad ditch lights
6-rear rack RTT
7-shovel + awning
8-above accessories and other gear weight = GVW over 5K lbs
The best MPG I can achieve while driving like a hyper miler is 17-18.5mpg...I think if I were to ditch my RTT, shovel, awning, Diamondback, camping gears, I might be get past 20mpg...
As for sway bar removal, the only reason for doing that is not to loose much weight but for articulation...I know many Taco drivers who run without them and have no issues...I've thought about doing the same...
Maybe I’ll be the first to report back if I take it off. Would that be allowed in this forum?
Of course...do beware that without a front sway bar, the truck will be more tail happy...
Robert T
Air Force Retired
What’s wrong with Starbucks and soy?
Chris M
Surprise, AZ
2021 Ranger XLT Sport 4X4
Security Supervisor
They're sponsors on Tacoma World forum.
This forum is for real truck people.
And their pets. Always their pets.
