Superdannyboy
So a rep from icon said that to start they will adjust the shim stack in the rear shocks to work with the spring rate of the deavers. I'm sure this alone will get me within tolerance of what I'm after.Its a lot harder to adjust in compliance for a leaf spring over a coil spring. I am sure Deaver makes a more to spec leaf then other company's. Maybe the leaf has to be altered. Give all the information you can to the Suspension Specialist. Write down what you think you are trying to achieve. What adjustments you made and how it felt. Did it improve or get worse for your application. The more information the better. Read about low and high speed damping.
It will be interesting what they say about the quality of the Icon shock. Please relay this information back. Would be nice to know how rebuildable the Icon Suspension is and how it compares to other manufactures. In some areas you may find a better suspension tuner in the motorcycle industry. Unless you have a large 4X4 off road community. I have a guy in my area that just does motorcycle suspension. Send the shocks to the right people or you may be wasting your time. Someone who has made a career out of it.
Regarding the post that was deleted. The person was not taking the best example to alter. It was an Eibach shock. It may seem incorrect to grind off the peen marks on the nut that holds the shim stack on, but that's what you do. Then you repeen the nut back on so it will not come off.
You do not want to play with this if you do not know what you are doing.
I have no idea what goes on inside but I have spent a few hours reading on it. I'm really busy as we all are. From may of this year to may of next year I have 18 classes left to finish my mechanical engineering degree. I'm knocking out 3 right now and in fall I have 6 classes then I'll do 2 in wintermester then spring I'll have 6 classes and I'll take my last class in maymester. I'm working full time in a manufacturing shop programming CMM's. Also have a baby on the way. We make time for what we want but man is my time limited to really tweak with things right now. Lol. I'm excited for what is to come with the shocks.
