Stuck Accelerator
A coworker had his accelerator stick on him yesterday in his Chevy Tahoe, and nearly burned up his brakes and tires getting it back home. He promptly had it towed to his favorite shop. They found the floormat to be the culprit! I about busted a gut laughing, you have to know this guy!
Dr_Strangelove
Adam
Henderson, NV
'22 XLT Supercrew 4x4
Art, Design, Photo & Video
LawnMM
Rich
'23 Ranger Tremor
He said he thought he had a vacuum leak.
Yeah I'm not even close to being at the point where I'd pretend to call myself a mechanic on the weekend...so feel free to explain how this works for me
But what would a vacuum leak have to do with a stuck accelerator? Isn't acceleration usually under positive pressure? ? I thought a vacuum leak would hinder acceleration not promote it ??‍♂
I am not exactly sure myself, but I think he thinks with uncontrolled amount of air getting into the carburetor can cause uncontrolled RPM. He said something like that.
Yes a major vacuum leak , can cause a high rpm idle.
But a related story, I too have had a floor mat catch under the accelerator pedal, years ago.
Put gear to neutral- pulled over on highway, noted the gas pedal felt weird, got out in investigated - pulled my NEW carpeted floor mat out from under the pedal , the NEW floor mat was promptly returned to the store and old went back in- my gas pedal was stuck at 65 MPH and a lesson learned, do not cheap out on floor mats and ensure proper fit
I am sure high idle is much different from full throttle.
He said he has WeatherTech mats but that the attachment points are worn out.
GitRDone
Andrew
Orlando Fl
2020 XLT
Real estate management
I had a scary moment many years ago when I tapped the brakes to disengage cruise and slow for a toll booth, and the car responded by flooring the accelerator! Thankfully the car's engine (325e) was no match for its brakes, and I was able to cancel cruise manually, but definitely a sphincter tightening moment.
Motorpsychology
Prescott, WI
Vagabond
Toyota found that many of the people that experienced the unpredictable acceleration problem had put aftermarket floor mats on top of the OEM floor mats.
pbethel
Patrick
kingman az
