Stage 3's 2019 Ranger Fox 2.0 Stage 1 Package Review!
ac_perks
Andrew
Portland, ME
2019 Ford Ranger Lariat 4x4
I've had this installed for about 4 months now, along with the BDS 3.5" UCA Lift Kit. Improved ride & handling on road, and off road is really impressive. Pics in my garage profile.
Ordered through Jason@Stage3 also - so thanks again Jason for the hookup!
Horadric Cube
Josh
Oh
2019 supercab xlt fx4
Thanks for the video! I've finally made my decision, Fox it is! Any deals right now?
Jason@Stage3
Jason@Stage3
Diamond Sponsor
Phoenix, AZ
www.stage3motorsports.com
2011 F150 5.0L
Web Team Overlord
I'm glad it worked out. Let us know if you need anything else!
We already have the Fox systems marked down for the month. I'll see if the sales guys can knock a few more bucks off and shoot you a PM.
Horadric Cube
Josh
Oh
Oh awesome! I hadn't checked in a few days, thank you!
T-Wrecks
Roberts, WI
19 XLT FX4 S Cab, FX4, 301A, Tow, Technology
Anybody run these with less than 2" of front lift? I don't want to fully level my truck for several reasons so I'm looking at maybe +1". I'm guessing less than the full ride height will be softer, but how much compared to stock?
Edit: I'm keeping stock FX4 wheels and tires
OxyGenIII
Corey
Minnesota
What roof rack is that?
I really want this shock setup and appreciate a ride on the softer side so these sound great.
Jason@Stage3
Jason@Stage3
Diamond Sponsor
Phoenix, AZ
2011 F150 5.0L
Web Team Overlord
It'll be softer, but not by a ton. It's tough to say, since we threw ours on at their out-of-the-box ride height, and even if we did lower them a smidge, it would still be a qualitative assessment.
Just make sure to use a wall or floor mount spring compressor when you do drop the collars. Ride height is not worth a maiming.
That would be the Rhino Rack Backbone with Pioneer Platform Kit.
Install is...interesting.
T-Wrecks
Roberts, WI
Looks like the ride height adjustment on the Fox 2.0 is via threaded collars, or am I missing something? That way you could raise and lower at will just have to make sure they are the same.
Jason@Stage3
Jason@Stage3
Diamond Sponsor
Phoenix, AZ
2011 F150 5.0L
Web Team Overlord
They do use an adjustment collar. However, that collar is at the bottom of the coilover and is under spring tension. To adjust the coilovers' ride height (either up or down), you need to compress the spring, loosen the collar's retaining screw, and then turn the collar accordingly by hand.
You can see it here at the op of this image:
2019%20ranger%20fox%2020%20ifp%20performance%20series%20front%20adjustable%20coilovers_004.webp
T-Wrecks
Roberts, WI
Thanks. Looks just like my motorcycles albeit a larger spring. With them you just turn the collar, no need to relieve spring pressure. So do they provide guidance on how to set different ride heights? I know the ratio isn't 1:1 (1" longer/shorter = 1" lift/drop), does anyone know what it is?
Jason@Stage3
Jason@Stage3
Diamond Sponsor
Phoenix, AZ
2011 F150 5.0L
Web Team Overlord
Talked to Fox, and they said that it's roughly a 2:1 ratio between the coilover thread and the ride height of the truck. The coilovers usually come out of the box set at 2.5" of ride height, so to get down to about 1"-ish of height, you'd drop the bottom collar by 3/4" of an inch.
Dmax
Denver, CO
Another video on the fox 2.0 install with torque specs. Enjoy
Shermy452
Ranger 2019 lariat fx4
Hey gentlemen. New to the ranger fam. Have a 2019 fx4 lariat. I got a great deal, and I probably won't be doing as much offroading, as I would daily driving. Was wondering if the fox kit would make for a smoother ride on street driving? I've been noticing a very soft and wavy ride.
Jason@Stage3
Jason@Stage3
Diamond Sponsor
Phoenix, AZ
2011 F150 5.0L
Web Team Overlord
The Fox 2.0s do a lot to smooth out the ride and calm the rear end down. However, if you’re not going to be off-roading often or very aggressively, you will get nearly the same result on the street from something like the Eibach Pros or Bilstein 5100s (if they land sometime this century) and save some cash for other things.
Jake596
Jake
Nevada
2019 Ranger XLT/2013 F-150/1976 F250
Installed my Fox 2.0 kit from Stage3 last weekend and it was fairly easy with the video made by Stage3. Some things to be mindful of are, the CV axles will separate and need to be pushed back in on the spline, was really quick on one side, took me forever to get the other side lined back up and pushed in. If you dont have help like me, i used a jack under the A-Arms to get the brake assembly lined up with the upper control arms, just gotta take your time and make sure nothing is binding. The biggest surprise catch was the little support guide arms (not sure the proper name) popped out of the ball joint on both sides when you make room for the coil by pushing the A-Arms down, so took large channel locks and popped them back in, which was easy and quick, but this could easily be overlooked if your not paying attention. All in all it took me about an hour each side, taking my time, cursing when needed and washing down chips and salsa with purple mountains :like:
