SOLVED: SuperCab Rear Seat Broken Floor Latch, Replaced Under Warranty
Porpoise Hork
Bret
Houston
IT
the discoloration could be the result of some kind of impurity in the plastic, maybe a few bad pieces in a batch
This white discoloration on the latch cover and the adjacent trim is consistent with exposure to cyanoacrylate, the active compound in Super Glue. You will see this happen when attempting to glue ABS plastics. You need a special glue to bond ABS and Superglue isn't one of them.
Wouldn't surprise me that someone in Make Ready screwed up and tried to glue it instead of reporting the issue so it could be replaced.
LightingBlue
Seattle
Fx4 off-road Larit Supercab (2019)
Those clips are pretty thin. We haven't liked the design when we were doing interior detailing of the SCAB.
Will try to take some close-up pics tonight to see if there is much difference between them or signs of fatigue or schmoo as yours had.
PineyKingsnake
South Jersey (Pine Barrens)
2019 Ford Ranger Lariat FX4
Retired Military
Sort of related. Within a week of having my truck home had to take it into the dealer to fix the rear seat "uplatch." It stuck in the open position. I tried a small dab of white grease but I wasn't going to mess around too much trying to get it working again while its under warranty. Latch issues may be a trend with this truck.
Doc
Doc
Live oak fla
Not a major issues by no means.
Brought my new truck home yesterday and was just checking out the rear jack storage location which required the removal of the rear jump seat base.
When I went to pull the tether to release seat base the plastic housing literally grenaded into two pieces. Upon inspection it looked like the plastic was corroded ??
Took some photos of the issue and shot it to dealer who had no problem ordering replacement part.
I feel like these latches maybe prone to breaking a few more times though...don't seem very robust.
On a side note when the new part comes I'm wondering exactly how I get that latch assembly out of the floor!
Mine did the same thing..
regards
