Smoothest ride? Shocks, spring rates, etc...
zn105
Pat
2019 Ranger Lariat FX4 Sport Package
I am in search of the smoothest ride. I became very weary of the neck pain on the highways from the harshness of the larger highway seems and the wallowing feeling also. Ford must have worked hard to get both of these effects so perfectly. I have a 2019 4WD Lariat FX4. I tow a 3500lb pop up a few times per year and don't carry much load in the box very often. Extreme off road not a concern but occasional bumpy dirt roads.
1) So far I put Eibach shocks on the rear and they seemed to firm up the roll situation.
2) I then put the Icon springs on the rear and definitely a softer ride with the extra leaf left out. Would recommend this for the ride and additional flex.
3) A couple weeks ago I put on the Eibach Pro Truck height adjustable front struts set at 2.25" with stock springs. This seems to improve handling and the wallowing. Lower speed ride seems smother but I still have a harshness on the highway ride bumps.
In talking to Eibach tech about the harshness we had a conversation about spring rates. Their springs are slightly lower spring rates than original FX4 4WD. I started researching spring rates of original springs. I found a chart that indicates four spring rates depending on load capacity rating but it does not correlate them to model. Found some door stickers on line that seemed to indicate that 2WD models had the lowest front end GAWR. I found four Ford Ranger spring listings that do not indicate their rate or spring wire diameter like the chart does but does loosely indicate what Ranger model they are for with some discrepancies. I ordered two of the spring models that I thought were the lowest spring rate and figured I could use the height adjustment on my struts to make up any squat due to my heavier load on a lower spring rate. I thought I could confirm the lowest spring rate by measuring the wire diameter when they arrived. In the mean time I thought I would check the wire diameter of my springs assuming I had the third stiffest rate based on my GAWR and the chart. Well it turns out I already have the lightest spring rate available!
4) Trying to feel where that harshness might be I though maybe the Eibach in the front maybe the last piece because I discovered I already have the lowest spring rate. After some more highway driving I thought the rear was still a little harsh so I put the FX4' shocks back on the rear. It helped a little with the harshness! Not sure if I suffered in stability but I still have the Eibachs up front so they are helping with that. May try the Bilsteins in the rear.
? for the group
I ordered the Bilstein B8 5100 height adjustable for the front and am thinking of swapping out the Eibachs. Will it be a better ride on the highway and worth the 3-4 hour strut swap out? My goal now is to get rid of the harsh highway jarring. I would even put up with some of the wallowing for a softer ride if need be. Almost there.
Appreciate the thoughts and input.
Joeiconic
I think roughness over those small imperfections is as much about air pressure as much as anything else, so what air pressure are you running? It’s a body on frame truck and will not ride like a limo, so you may be chasing a ghost.
zn105
zn105
Pat
34 PSI right now. Tried recommended 30 and 38 before my current set up. 38 helped with wallowing. I am thinking about Bilstein 4100 all the way around with a 2.5 inch spacer up front also at this point.
Joeiconic
I have 5100’s all around and love it, but it’s not going to resolve your complaints any more than what you’ve already tried, IMO.
Aonarch
Alec
North GA/ Montana
RANGER_MARC
MARC
Delaware USA
FORD RANGER LARIAT 2019
TEACH
? for the group
I also have a 2019 4WD Lariat FX4 but with the Black Appearance Package, which moves the wheels up to eighteen inches. So far I have put on the Ford (Fox) Performance Leveling Kit, which helped a lot. I have been thinking of adding the Icon springs to the rear, with the extra-leaf left out, as you say. Reading your recommendation, I am even more convinced this is the way to go. I may do the Hellwig anti-sway bar as well, but let's wait and see how the Icon multi-springs work out. Thanks for your input!
1pt21gw
West Coast
Ye' Ole Traveler
I'd say different tires and air pressure at this point.
NOVA_Ranger
Northern Virgnia
I must have got a special truck, or I’ve just driven enough older trucks. I think the Ranger rides great (for a truck)….doesn’t float down the road like a Caddy or corner like a BMW M3, but I’m pretty sure it wasn’t designed to do either. Expectation management is key.
NOVA_Ranger
Northern Virgnia
The truck does tear it up off-road, it hauls stuff, and it does pretty good donuts. Good enough for me.
zn105
zn105
Pat
Stage 3 said maybe a coil over set because they are "matched" but not convinced I can't get the right highway shock to go with my spring which from all accounts is the lightest spring for the Ranger. Maybe there is one that is longer but the spring rate would still be heavier. As our vehicles sit the only thing compressing the spring is the weight of the vehicle because the strut has some upward travel for flex so it can not be compressing anything. "preload" only adjusts how high the spring sits on the strut. Someone correct me if I am wrong as I am just reasoning this out and not an expert. Do shocks have different valves for the up compression and the down extension or just one valve? It seems like what I am feeling is the shock not letting the spring take in the up travel of the larger bumps as the smaller ones are handled fine.
zn105
zn105
Pat
Should my neck hurt from rough highway seems or my passengers voice skip as they are talking?
Sooooooo......... As a freindly reminder you did buy a Ford Ranger and not a Rolls Royce.....
With the modifications you did you are most likely getting what you want. Just understand it will still ride like a truck.
NotBudule
XLT
I thought the consensus in a previous thread was Fox was the more comfortable ride ? ... it's been said on here i believe that a couple sand bags near the rear wheels smooths out the road a bit ...
