LoneRNGR
- First Name
- John
- Joined
- May 8, 2020
- Threads
- 11
- Messages
- 470
- Reaction score
- 862
- Location
- Lubbock, Texas
- Vehicle(s)
- 2020 Ford Ranger XLT
- Occupation
- Systems Engineer
Regarding last two pictures: The corrosion on the control arm might cause more rapid oxidation of the rubber bushing. If you are doing suspension work, you might replace these parts sooner than later, so it might not be of too much concern. The last picture where the swaybar links fit through the spindle/knuckle: I’m glad there is no corrosion inside. This is an area that will constantly be exposed to moisture. I would loosen up the swaybar links and check that annually. The rest of it, while unsightly, isn’t too concerning.There are multiple areas but here are a few pictures I took:
. That's what you came to these forums for, right? ?
